Postby DMan1198 » Fri Jan 03, 2014 8:38 am
I plan on pulling my engine around June so it'll be about 6 months minimum
It's almost t-shirt weather here at -11c
Postby RCCUMMINS89 » Fri Jan 03, 2014 8:57 am
No grids here.... and advanced a tooth skipped and then some on a WORN OUT engine.
It starts without being plugged in... even at 0, but it takes some serious cranking when it gets below about 20.
Postby skilletky » Fri Jan 03, 2014 9:01 am
i just tried to start my 1stgen, not happening. it aint been started in a few days and is not plugged in. when its this cold out, ill pull my shut off cable, let it crank over a few times, then let the cable go. usaully starts right up. not this time
skilletky
Postby CumminsPower59 » Fri Jan 03, 2014 9:32 am
I don't think I have enough vacuum, but I got the valve zip tied open. I noticed it earlier this year that it wasn't opening at all, and until my new-ish heater tubes come in, I just zip tied it open. It blows warm at the vents, but not enough to warm up the cab nice and hot like it used to. I'm gonna try checking the doors in the heater box and see what else I can do to get some heat out of this turd.
Postby DMan1198 » Fri Jan 03, 2014 3:26 pm
Mine always made good heat. It did of course take a while, but it was good
Postby ihredneck » Fri Jan 03, 2014 4:13 pm
DMan1198 wrote:Mine always made good heat. It did of course take a while, but it was good
My corn stove does too :lol:
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby cmann250 » Fri Jan 03, 2014 4:40 pm
RCCUMMINS89 wrote:No grids here.... and advanced a tooth skipped and then some on a WORN OUT engine.
Why? You're just putting more and more nails in that's poor engine's coffin.
CumminsPower59 wrote:I don't think I have enough vacuum, but I got the valve zip tied open. I noticed it earlier this year that it wasn't opening at all, and until my new-ish heater tubes come in, I just zip tied it open. It blows warm at the vents, but not enough to warm up the cab nice and hot like it used to. I'm gonna try checking the doors in the heater box and see what else I can do to get some heat out of this turd.
Could your heater core be plugged up? Either on the inside or outside? I found all sorts of crap in the box years ago that could obstruct heat flow. Who knows what's on the inside either.
Postby RCCUMMINS89 » Fri Jan 03, 2014 4:49 pm
Why no grids? Didn't work....wanted to see if people were right on this "gain more power without grids" non sense... ya, you don't gain power. LOL
Postby CumminsPower59 » Fri Jan 03, 2014 4:56 pm
RC, I went through that heater core when I rebuilt the truck, it was in excellent shape as it had just 50k on it. There must me a flow issue or something, the fan is blowing, but not as hard as it should be. The possibility of low vaccum might be affecting the internal door operation...
Postby cmann250 » Fri Jan 03, 2014 6:21 pm
http://www.weather.com/weather/5-day/La ... 47905:4:US
Sunday and Monday will be fun.
Said no one ever :lol:
Postby PToombs » Fri Jan 03, 2014 6:57 pm
I had to go to the doctor this morning, so I wasn't in a hurry to leave. I shot the side of the truck with my temp gun and it said -14. I took the car. :lol: I'm going to get more kerosene this weekend and adjust the fuel in the truck. I dumped in the 5 gallons I got for my salamander last night but still didn't trust it. Another 5 gallons or so should do it. It's supposed to be back around or below 0 here by the end of the week.
Heat wave tomorrow, up to 23!
Postby muddpar » Fri Jan 03, 2014 9:57 pm
it was -6℉ according to my cell phone this morning, but my car said it was -13℉ driving to work.
Do you guys have any driving tips for a dually on icy roads? If I drive in 2wd or 4wd the back of the truck is all over the road. Snow covered and icy roads that are flat are no problem. But if I drive on back country roads with deep icy 2 track grooves back of the truck is all over the road. Cars coming at me slow way down and give me more of the road because they see my truck all over the road. They probably think I'm drunk. This is my first year driving a dually in the winter. I always parked the duallys for winter. I just retired my 93 w250 plow truck this winter do to rust, electrical and brakes problems, I only use it now to plow the driveway. If I put a ton of weight in the back of the truck will that help me drive out of the grooves and keep the truck falling back into the grooves? or is this just a dually thing
93 chevy k3500 dually with a 92 Cummins 4l80e, 4.10 gears Aurora 3000, lppp, ps intercooler, cooler tubz
92 chevy c3500 dually 6.5l turbo diesel
93 dodge w250 360 mpi plow truck
85 dodge 2.5 ton 440 on 57" tractor tires
57 dodge d400 inline flathead maybe future Cummins
95 dodge incrapid 3.5l daily driver
muddpar
Postby matthewh » Fri Jan 03, 2014 10:47 pm
muddpar wrote:it was -6℉ according to my cell phone this morning, but my car said it was -13℉ driving to work.
When I drove mine last winter for the last couple of months, I had an 11.00x20 semi tire filled to the top with cement, had something like 7 bags of the premix stuff, plus 10 bags of 80lb tube sand. Still had some traction issues, mainly on deeper snow it wanted to hop, and the slop it was interesting.
You could always take inboard wheels off and just run 2 wheels outback, if yer scared :D
matthewh
Postby ihredneck » Sat Jan 04, 2014 6:42 am
DMan1198 wrote:I plan on pulling my engine around June so it'll be about 6 months minimum
Hmmm, I'll be married then and no time to work on things like now :lol:
2000 VW Jetta TDI
ihredneck
Postby dazedandconfused » Sat Jan 04, 2014 8:14 am
Throw a thousand pounds in the bed and rock on. This is the first year I've had a 4wd I've always ran a 2wd dually.
