Postby DMan1198 » Sun Jan 05, 2014 7:34 pm
I think we have about 2 feet as well. There is a hard base so it's good for snowmobiling
Postby DodgeFreak » Sun Jan 05, 2014 10:06 pm
What I did tonight...hope it helps...its two 650cca batteries. If not the local IH dealer has 925cca for 80 bucks apiece. Ill try and get a finished picture
Postby Hansen01 » Sun Jan 05, 2014 10:26 pm
Had 2 900's in mine and they did great. Seeing this gets my wheels spinning in my head again about where to mount both of mine when i get that far the second time 8)
Under construction...
Hansen01
Postby DodgeFreak » Sun Jan 05, 2014 10:37 pm
Im pretty sure this will be temporary. I dont like the idea of that much weight sitting on the battery tray. I think im going to mount them on the frame or one in stock location and move the washer tank and mount one there
Postby Hansen01 » Sun Jan 05, 2014 11:00 pm
I had them both sitting on the single battery tray for a year, truck even rolled and battery tray was still A-ok so that shouldnt worry you lol. But i think it looks a little better when there seperated. ( However if i do decide to put them side by side i do have a second battery tray ;) )
Hansen01
Postby dazedandconfused » Mon Jan 06, 2014 4:21 am
Well we barely got a dusting in some places and nothing in most of the area. Temps bottomed out fast and all the wet area from the rain is now ice. I worked for about 1/2 an hour salting and then came home.
Postby cmann250 » Mon Jan 06, 2014 5:25 am
Lafayette's more or less shut down. A lot of factories cancelled first shift. I may as well not plow because we have a 20 MPH wind.
Postby Philip » Mon Jan 06, 2014 6:50 am
We are showing -14 right now. We had 10 to 12". That was fun last night trying to move trailers with the yard truck. :lol:
Postby dazedandconfused » Mon Jan 06, 2014 7:52 am
We are at -2 and dropping with 15-20mph winds. This is the coldest I can ever remember. The wind is howling around the house and the little snow that we got is blowing all over
Postby cmann250 » Mon Jan 06, 2014 7:58 am
I'm stacking the deck. I brought my battery inside. :lol:
The first time I tried to start my truck I got the grid heaters for 60 seconds as expected then the SSSSSSSLLLLLLLLOOOOOOWWWWWW crank a couple times over. Nope :lol:
Dad's 7.3L was plugged in overnight and it fired right up. I'm jealous of his 2 new batteries.
Postby dazedandconfused » Mon Jan 06, 2014 8:00 am
I plugged the 7.3 in but I don't think my block heater works on it. It started but was a grumpy bastard.
Postby CumminsPower59 » Mon Jan 06, 2014 8:17 am
My pile is gelled up...again. I need to do something different, like start running 70/30 mix of kerosene or something. I will never buy another f'n "anti-gel" product as they don't work, plain and simple. It was even plugged in and had a nice and warm block. My VW started right up and ran like a champ, and it still has 2% bio in it and it isn't gelled...
Postby cmann250 » Mon Jan 06, 2014 8:35 am
dazedandconfused wrote:I plugged the 7.3 in but I don't think my block heater works on it.
Hey, now is the perfect time to put a block heater in it. Nothing like a sleeve full of coolant when it's 0* :lol:
I wouldn't laugh if I hadn't done it.
Ike, I would suggest you not gamble. Your luck sucks. That's the only thing it can be because you're doing everything right.
Postby dazedandconfused » Mon Jan 06, 2014 8:51 am
It will get a new block heater when it goes into the 83 Caleb I'm not screwing with it now.
Postby RumbleFish » Mon Jan 06, 2014 9:26 am
-11 before windchill here. I havent been out yet as we have a travel restriction. Plows and emergency vehicles only. I put a heavy dose of howes in. It should start but who knows after reading about Ikes luck. I was out a bit last night and the 255/85 muds I have on did freaking awesome in the 10" or so we had at the time. I think we now have about 14" on the ground. Ill be heading out to my parents' soon "to check on them" but ill be playing the whole way!
