Tacoclaw wrote:Dun dun duuuuuuuuuunnnn.....
ellis93 wrote:So.....how's that truck pull with the blower.
RCCUMMINS89 wrote:Spicer...... last year I was in a pinch and bought the "o'reilly high end ones". Since then I think I've replaced my rear joints, oh.......5 times probably (I don't remember exactly). That driveline and yokes are factory and in excellent shape. But, there comes a point where you just start over.
I've got a 2nd gen front shaft that will be going in.
Tacoclaw wrote:I has a chat with Mr. Nixon over on CompD and I'm going to put 2ndgen ICs in both trucks. Since I have to hack up a core support to keep my '90 grills, it seems to be the easiest way. I'm heading up north a bit Saturday morning to pick up the two 'coolers. I'll keep my buddehs updated.
ellis93 wrote:......I can't find them and my head hurts from looking thru all the bs.
cmann250 wrote:Tacoclaw wrote:I has a chat with Mr. Nixon over on CompD and I'm going to put 2ndgen ICs in both trucks. Since I have to hack up a core support to keep my '90 grills, it seems to be the easiest way. I'm heading up north a bit Saturday morning to pick up the two 'coolers. I'll keep my buddehs updated.
You're still going to have to trim or sand on the back side of the grille a bit. I didn't see any way around it.ellis93 wrote:......I can't find them and my head hurts from looking thru all the bs.
Too much BS? It's a wonder you stick around here
Tacoclaw wrote:cmann250 wrote:Tacoclaw wrote:I has a chat with Mr. Nixon over on CompD and I'm going to put 2ndgen ICs in both trucks. Since I have to hack up a core support to keep my '90 grills, it seems to be the easiest way. I'm heading up north a bit Saturday morning to pick up the two 'coolers. I'll keep my buddehs updated.
I was asking him about keeping the center of the IC'd core support and welding my early headlight buckets onto the sides of it. He suggested it would be easier to just hack up my older core support for a 2ndgen setup and trim the plastic to fit. I agreed when I thought on it for a while.
