dazedandconfused wrote:I've been trying to find a cheap 24v to put in the Duck with a VE but everyone has gotten insane on the price of engines around here.
DMan1198 wrote:Caleb. I'll tell you right now tuning a cr is not that easy. It takes hours to go over the maps, and unless you can data log everything is a shot in the dark. I had to redo everything I'd already done, and it took about 3 hours, And unless you use a manual vb trans tuning is an almost incomprehensible mess. You'd be far better off with a p pump 6.7 with compounds, full manual 48, then all the other things you said
cmann250 wrote: '92 or '93 W250 regular cab. Stand alone 6.7L with twins, manual VB 48RE, flipped 271, and a D80. Complete with dog dishes!
cmann250 wrote:DMan1198 wrote:Caleb. I'll tell you right now tuning a cr is not that easy. It takes hours to go over the maps, and unless you can data log everything is a shot in the dark. I had to redo everything I'd already done, and it took about 3 hours, And unless you use a manual vb trans tuning is an almost incomprehensible mess. You'd be far better off with a p pump 6.7 with compounds, full manual 48, then all the other things you saidcmann250 wrote: '92 or '93 W250 regular cab. Stand alone 6.7L with twins, manual VB 48RE, flipped 271, and a D80. Complete with dog dishes!
I'm not implying that I know what makes a CR tick, but some folks named Fleece do. A stand alone ECU would help, and I am sure PCS has the 48RE figured out if I wanted it to shift itself.
I love mechanical diesels, but in a theoretical DPC build, a CR is the way to go because of the variation available. Try to vary duration, pulse width, and timing with a P7100.
fatty wrote:Well Dman if you think that's all there is to making power with a ppump, I don't think you'll get very close to your 1200 HP goal. That's like saying all you have to do to make power with a ve is crank the power screw and mess with the smoke screw, not even close.
cmann250 wrote:Post 3000!
Watch out Pete, I'm on your heels!
AHineman wrote:Not mentioning any names, but some people talk too much.![]()
