Postby RCCUMMINS89 » Wed Mar 12, 2014 9:23 pm
Yea.. but we don't have as cool of goodies to tune. Our little ve doesn't have all of those options.
Postby DMan1198 » Wed Mar 12, 2014 9:56 pm
I still think it's cool to tune a ve. With a cr it's hitting keys and staring at a screen. With the ve there's the physical aspect that you just don't get with new stuff
Postby CumminsPower59 » Wed Mar 12, 2014 11:29 pm
I enjoy messing with the VE...but one thing I can't figure out on mine is that right now it is about halfway between stock and max on the fuel screw...if I turn it in more it does what is should except when side stepping between part and full throttle it will damn near die and kick right back up to idle. The further it is in, the worse it gets with the RPM drop, at just about max, it'll die when the RPM's come down from part-full throttle. I can't figure it out, so it's been set mid range for now :?
Postby Tacoclaw » Thu Mar 13, 2014 5:02 am
I had a Chrysler Conquest, it was an awesome little car. Unfortunately, they used a throttle body injection system that had a weird operating setup and it sucked wondering whether it was going to run right that day.
When it did run right though it was an awesome car. There wasn't an intersection around I didn't leave sideways. That had was setup so that once you were sideways you didn't even have to mess with the steering wheel. It was easily controlled with just the throttle. I loved that car. 8)
Postby ellis93 » Thu Mar 13, 2014 5:57 am
Tacoclaw wrote:I had a Chrysler Conquest, it was an awesome little car. Unfortunately, they used a throttle body injection system that had a weird operating setup and it sucked wondering whether it was going to run right that day.
I rode around Huston and made a few trips to and from there to here in a starion (same thing). It was a cool old Car.....except when that weirdo mass air thing started flaking out. That thing would screw the cars whole world up and make it a turd.
The guy that owned it worked late shift at a Krogers There and when it rained would be out in the parking lot trying to do action movie driver stunts. He'd act like a real clown in it.
Postby DMan1198 » Thu Mar 13, 2014 6:46 am
I kind of want a chevette to do some kind of turbo engine. Tub it and run some big slicks. I feel like it could be really quick
Postby RCCUMMINS89 » Thu Mar 13, 2014 7:32 am
CumminsPower59 wrote:I enjoy messing with the VE...but one thing I can't figure out on mine is that right now it is about halfway between stock and max on the fuel screw...if I turn it in more it does what is should except when side stepping between part and full throttle it will damn near die and kick right back up to idle. The further it is in, the worse it gets with the RPM drop, at just about max, it'll die when the RPM's come down from part-full throttle. I can't figure it out, so it's been set mid range for now :?
Mine used to do that when it was near runaway..... it doesn't do it anymore though??? Fresh return springs maybe?
Postby CumminsPower59 » Thu Mar 13, 2014 7:38 am
I got some that I could throw on. I'm thinking it may have something to do with the governor assembly sticking or not catching the RPM's as they come down...or something of the sort, that's the only thing I can think of....
Postby 1STGENFARMBOY » Thu Mar 13, 2014 9:19 am
Dave...have you heard from SWANK ?, just wondering how he is doing.
Postby RCCUMMINS89 » Thu Mar 13, 2014 9:25 am
Come to think about it, I believe mine quit when I put in the 3800 spring. It may be fighting the governor just enough to not allow it to do it anymore. Mine used to do it when it was cold, but wouldn't when it was warmed up.
Postby DMan1198 » Thu Mar 13, 2014 11:32 am
I now want to get The Roo Hunter running with a ve again, and run it until I have all the parts to put together the built engine. So I'm going to finish the compounds, put in my sump, and an inline filtration system, run that into my raptor, rebuild my ve, and get my injectors checked out. I think I want to go to a 3800 rpm gov spring, add a timing spacer, loctite the front seal, and reseal it. Anyone know where I could get the pump stuff?
Postby dazedandconfused » Thu Mar 13, 2014 2:30 pm
Well looks like I need a pcm for the Ford. I swapped in my 5speed 95 pcm and the pos started.
Postby ellis93 » Thu Mar 13, 2014 3:54 pm
dazedandconfused wrote:Well looks like I need a pcm for the Ford. I swapped in my 5speed 95 pcm and the pos started.
Bummers. :?
Postby dazedandconfused » Thu Mar 13, 2014 3:56 pm
Ellis you have any input on the cardone reman pcms? I haven't checked with Ford but I don't want to pay $5-600 for one.
Postby ellis93 » Thu Mar 13, 2014 4:23 pm
They're fine,least I haven't had a bad one from them.....yet. Should be in the 200$ range for that truck too.
