DMan1198 wrote:Maybe Ellis has his April fools on the ninth
DMan1198 wrote:...and the quote in Caleb's sig is pretty much my approach to life
DodgeFreak wrote:serviced the engine on the crew, and while I had it up in the air checked ball joints ect........both upper and lowers on both sides are shot, both wheel bearings were loose....soooo.....looks like I'll be doing ball joints before I drive it to much....
DodgeFreak wrote:use a jack under the lower control arm to keep the suspension compressed then I grab the top and bottom of the wheel and try to move the tire in and out. I always leave them alone if I have to work pretty good to get movement. It gets tricky if your wheel bearings are loose to figure out if its the ball joints or wheel bearings.
