Postby fatty » Tue Apr 22, 2014 5:47 pm
BC847 wrote:I'll be glad when they finish building the new track. New injectors and I'm ready for track tuning. :bh:
What did you end up getting for injectors? Did you get more from Scheid or someone else?
Postby fatty » Tue Apr 22, 2014 6:32 pm
Found this on FB today. http://news-hound.org/hidden-dam/
Crazy goats anyways
Postby BC847 » Tue Apr 22, 2014 8:23 pm
fatty wrote:What did you end up getting for injectors? Did you get more from Scheid or someone else?
Eric set me up with some Bosch 5x18 SACs, flow-honed to match the flow of the Scheid 6x16 VCOs I'd been running, plus some pintle work.
They're easy to smoke with a light load, no boost, below 1800 engine rpm. Let's face it, low injection pressures (relatively speaking) through a large hole don't atomize well with small spurts.
On the other hand, at WOT, they clean up much better, and a little cooler compared to the 6x16s, all else the same. Combined with some funky injection event timing stuff, they seem to pull up through the rpms QUICK!
I've had them for some months now, mostly driving to, and from the coast during the weekends. The overall mpg is up (roughly 16mpg) with perhaps 150 miles of the tank at 75 ~ 80 mph, compared to the 6x16s.
Still gotta do some more stuff with the IP. 8)
The local 8th mile track, formally known at The Dunn-Benson Drag-strip, has been bought by Galot Motorsports. http://galotmotorsports.com/
-> They have deep pockets. :shock:
The track is now called The Galot Motorsports Park. http://www.galotmotorsportspark.com/
In a nutshell, they've ripped up the old track, and built it like one ought to be. Lanes plenty wide, proper barriers, full concrete strip.
They've even included a track surface temperature control system (embedded heating/cooling for the first 300').
Freshly placed left lane, next to the ready to be placed right lane. Note the Dodge truck for size reference
Hope I don't phuck it up with an oil slick. :oops:
Postby RCCUMMINS89 » Tue Apr 22, 2014 8:43 pm
Hey, I've seen (heard) of guys that got waived off from puking so much oil out the blow by while trying to spool their turbos.
Postby DMan1198 » Wed Apr 23, 2014 6:45 am
I want to get my truck onto the strip this summer, and see what they'll do
Postby cmann250 » Wed Apr 23, 2014 8:22 am
:bday: Jon!
Our 1/4 mile track is already open around here. I intend to make it up this summer, but here's to intentions. :roll:
Postby DodgeFreak » Wed Apr 23, 2014 8:44 am
Tacoclaw wrote:Had a little incident this weekend, the Rhino's wristpin decided its job was just a little too tough.
Looks like scrap....lol
Postby DodgeFreak » Wed Apr 23, 2014 8:53 am
Hauled off 3207lbs of scrap...and didn't even put a dent into what we have.....Although I think I need more air....I pulled a decent hill probably 1\8th-1\4 mile long and egts went to about 1300, and i only have the power screw in 2 turns....
Postby Tacoclaw » Wed Apr 23, 2014 9:24 am
Nothing a little $$ can't fix, I'm looking into building it a little bit since I'm down this far. Definitely going with a 686 big bore, but whether to stroke it to a 720...
Postby RumbleFish » Wed Apr 23, 2014 9:25 am
cmann250 wrote:Our 1/4 mile track is already open around here. I intend to make it up this summer, but here's to intentions. :roll:
I recall running there with snow on the ground. As long as the track was clear, it was on!
Postby DodgeFreak » Wed Apr 23, 2014 9:31 am
Tacoclaw wrote:Nothing a little $$ can't fix, I'm looking into building it a little bit since I'm down this far. Definitely going with a 686 big bore, but whether to stroke it to a 720...
Stroke it like you stroke hiney... :lol:
Postby ellis93 » Wed Apr 23, 2014 9:50 am
Damn :)
Levi how's the charger coming?
Postby cmann250 » Wed Apr 23, 2014 11:15 am
RumbleFish wrote:I recall running there with snow on the ground. As long as the track was clear, it was on!
From what I gather, they are pretty easy going, which is good because that means they probably won't ban me for life at the whiff of diesel fuel. On the other hand, track prep is supposedly non-existent. I suppose it wouldn't be a big deal with a live front axle, but that I don't have.
Postby Tacoclaw » Wed Apr 23, 2014 12:34 pm
It's an extra 4mm of stroke, so it'll be just like Hiney. :mrgreen:
The RC is chilling out right now. Nice weather showed up and it's tough for me to stay cooped up in the garage long enough to finish it. I did throw the front driveshaft in it and drive it outside for a pic, then pulled it back in. Haven't touched it since.
I need to pull it to another bay where I can get a forklift to the rear so I can swap the rear axle, then I just need to bleed the brakes, put the body stuff back on, and have a rear DS made. It should be a driver then.
Postby ellis93 » Wed Apr 23, 2014 12:41 pm
Cool beans! You are definitely more patient than I when that close. :lol: I was practically broken out in hives buffing my truck, I just wanna drive it ;) . Now that the shaft is out of it and one being made for it,I'm waiting again :?
