OPeration - "guaranteed to blow up"
Re: OPeration - "guaranteed to blow up"
Postby Tacoclaw » Sat Apr 26, 2014 6:56 am
Whaaaaaa, my driveshaft wobbles and my rearend is torn up, I hate power."
"Just bought a 14mm H&R, everyone!!"
:P
Postby RCCUMMINS89 » Sat Apr 26, 2014 8:48 am
I wish.... the pump I have to put it on completely needs to be gone through... it done got blowed up from the previous owner. If the carnage is too bad.. the h/r will go on my pump. And then I'll REALLY hope it holds together.
Postby RCCUMMINS89 » Sat Apr 26, 2014 8:50 am
Tacoclaw wrote:Whaaaaaa, my driveshaft wobbles and my rearend is torn up, I hate power."
:P
:mrgreen:
I will add... the Dana 80 is at full rebuild (except the power lok). No power issues there. It is merely my driveline angle. Coming off the case, it has a 9 degree difference between the case and driveline. That's over double the maximum recommended u joint angle for drivelines.
Speaking of something... Does anyone know the maximum number in degrees one can tilt an engine backwards. Without causing front shaft/bearing issues in the trans and oiling issues in the engine?
Postby DMan1198 » Sun Apr 27, 2014 6:00 pm
What are you at right now? I'm not an expert but oiling issues occur when the pickup isn't in the oil. Since the pickup on our engines is at the rear I feel like you could get away with a decent amount of angle on it without problems
Postby RCCUMMINS89 » Sun Apr 27, 2014 7:22 pm
Postby oldestof11 » Sun Apr 27, 2014 7:37 pm
May also want to look into larger lines with the smaller injectors. Just a theory.
Postby RCCUMMINS89 » Sun Apr 27, 2014 7:53 pm
Not a bad idea, actually.
Postby PToombs » Mon Apr 28, 2014 5:02 pm
How will larger lines help? It will only flow what goes out thru the injectors. I understand if you have big injectors and H&R setup it will get the fuel to and out of the injectors faster, but see no benefits to large lines with small injectors.
Postby diesel freak01 » Mon Apr 28, 2014 6:19 pm
I know this is apples and oranges but, on our tractor I have been told if you go too big with the lines (120) you lose horsepower over 093 lines. Not sure what size stock lines are but something to keep in mind.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby oldestof11 » Mon Apr 28, 2014 6:22 pm
You have more "squish" so in theory you have less strain on the rotor.
Postby DMan1198 » Mon Apr 28, 2014 8:12 pm
If you go with bigger lines be prepared for the possibility of a lope (they aren't fun to drive with)
Postby RCCUMMINS89 » Mon Apr 28, 2014 10:18 pm
What Jon said ^^^^^^^. However, I won't be going with bigger lines. It is a good idea, but I've got to face reality and well... it just won't happen (me being not that ambitious).
Postby ellis93 » Mon Apr 28, 2014 11:53 pm
RCCUMMINS89 wrote:What Jon said ^^^^^^^. However, I won't be going with bigger lines. It is a good idea, but I've got to face reality and well... it just won't happen (me being not that ambitious).
I smell something that has the oder of stockyard to it :lol:
Postby PToombs » Tue Apr 29, 2014 5:19 pm
oldestof11 wrote:You have more "squish" so in theory you have less strain on the rotor.
What "squish"? Rule #1 of hydraulics, fluids don't compress, that's how hydraulic systems work. ;)
Postby RCCUMMINS89 » Tue Apr 29, 2014 7:32 pm
It's not as simple as that though... because if that were 100% and the lines stayed pressurized.... one wouldn't notice a lope idle.
