2005 Rolling Chassis with a 1st gen on it
Postby mbdpp » Wed Apr 30, 2014 10:13 am
Hey guys I found a 05 rolling chassis that I want to set a extended cab 1st gen on it and use the 3rd gen power train and brakes and everything. any idea what I will need to make the plan work? What will be required to make the engine run? I am going to go with a NV5600 and a south bend dual disc clutch. For gauges I am going to have to get a wiring diagram from the first gen to try and make as much as possible work, I do not think it will be a problem as it is mostly very simple direct connection wiring instead of the new modern communication and ECM, BCM, etc.
Thanks
Brad
mbdpp
Re: 2005 Rolling Chassis with a 1st gen on it
Postby DodgeFreak » Wed Apr 30, 2014 10:43 am
with it being common rail you're going to have to figure out how to run the ecm. you might have to by pass the abs as that all feeds into a computer also. I'm not 100% on any of it with out studying both wiring diagrams. Also will the body fit on a 3rd gen frame have you taken measurements of that also?? Personally I don't see any gains from swapping a 1st gen body on a 3rd gen frame. If I was going to have a common rail I would buy a complete truck.
Users browsing this forum: No registered users and 72 guests
