Postby ellis93 » Wed Jun 04, 2014 11:33 am
Tacoclaw wrote:Quit yer bitchin', Ellis, they saved $30 a truck from not having to buy another fitting and return hose.
Totally worth it. :grin:
Bitchin? I'd like to say that I ain't bitching now,you should have heard me when I found out what was wrong with this thing :?
I boardered on insanity when I found out I had to remove all these parts again....pump,injectors,and complete rail/line system. To clean this
To add to things I just got off the phone with the injector shop.....one of there hands called me to tell me there was nothing wrong with those injectors. Bs I say,I got an extra gallon of oil......where in the hell did it come from? Gotta be a stuck one some where. I told him to look harder :? And call me back. I ain't stupid,one is/was bad.
I'm fixin to go work construction or something :roll:
Postby ellis93 » Wed Jun 04, 2014 1:15 pm
God smiles upon me :)
Getting all 8 replaced for free under the builders warranty.
Now I just have to get the rest cleaned up :(
Do y'all have any idea what gm wants for those injector lines and two rails? I do and it's freakin high.....1600$ :shock:
Guess I'll be dropping these in my chemical dip for carbs for a few days :lol:
Postby Tacoclaw » Wed Jun 04, 2014 2:07 pm
Any screens in those rails or lines?
Better check them pretty thoroughly, our 6.0 and dad's injectors had screens all over the place. Don't want them holding anything.
Postby ellis93 » Wed Jun 04, 2014 2:21 pm
Non that I can see Levi.
Postby dazedandconfused » Wed Jun 04, 2014 4:03 pm
That's the worst rail I've ever seen. Blow all the big sthi out if you can before you soak them. Speaking of 6.0 how is the crew coming?
Postby ellis93 » Wed Jun 04, 2014 6:18 pm
It ain't.....I have not had time to screw with it just yet. All the parts,additives,filters and fluids are here at the shop,just gotta get time to do it.
FYI people. Check out the walmart insert in your local paper,their having a tire sale. I just bought wrangler ats's for 119$ a piece in 265 70 17. Pretty good deal
Postby DMan1198 » Thu Jun 05, 2014 12:12 pm
The cr cummins aren't so bad. Just one rail to mess up.
On another note I'd been having a weird experience with jaeger where the rpms would be low then just jump when it went to third. Turns out the converter was locking. Now I just have to adjust 3rd so it stays locked, and pull pilot back to make it quieter. Then half the pilot on one of the tunes so it rattles more. Ahh isn't custom tuning fun
Postby ellis93 » Thu Jun 05, 2014 3:08 pm
Sometimes I get to work on/drive cool schit :)
Nice car.......except for the G wheels on it :roll:
Postby RCCUMMINS89 » Thu Jun 05, 2014 3:16 pm
I think the "g" wheels fit the car.
Ellis.... just because you get to work on it, doesn't mean the owner was ok with you also driving it. Just to make sure when you changed the oil it didn't put the tires out of balance... piss poor excuse man.
Postby matthewh » Thu Jun 05, 2014 3:23 pm
No fins out back, so a '55? Nice car, not a huge fan of the wheels either. Some of these cars look good with big wheels, but they have to flow with the style, them dont.
For instance, awhile back there was a mid 50's Buick in Hot Rod mag, built by Rad Rides by Troy. That had 20's on it, but they fit with the car. I'll try and find a pic.
Either way, sweet car, owner can do as he wants, if he likes it, all that matters
[img]/http://i305.photobucket.com/albums/nn226/MHaver/images2.jpg[/img]
matthewh
Postby cmann250 » Thu Jun 05, 2014 3:44 pm
Since we're talking old gasser trash... :lol:
I think my 460 needs the carb rebuilt/cleaned. Sometimes it'll run fine and then 10 minutes later I have to close the choke just to keep it running. It runs fine with the choke closed whenever it has those fits so I'm saying there's gum in the carb that works its way loose now and again.
Gas engines are so finicky.
Postby matthewh » Thu Jun 05, 2014 3:52 pm
Before you rebuild it, try reving it up abit, then choking the carb with a rag, the vacuum caused by this is suppose to suck all the sthi out of the tiny orifices and help it run better. While not a perm fix, may get you by for a bit.
I've not tried this, just witnessed it, really seemed to help
matthewh
Postby cmann250 » Thu Jun 05, 2014 3:56 pm
That is right up my alley! :lol:
Thanks for sharing.
Postby ellis93 » Thu Jun 05, 2014 4:00 pm
RCCUMMINS89 wrote:I think the "g" wheels fit the car.
Different folks....different strokes.
I just aligned it up,that requires drivin :mrgreen:
Postby ellis93 » Thu Jun 05, 2014 4:07 pm
matthewh wrote:Before you rebuild it, try reving it up abit, then choking the carb with a rag, the vacuum caused by this is suppose to suck all the sthi out of the tiny orifices and help it run better. While not a perm fix, may get you by for a bit.
Yep
Get it warmed up,with the air cleaner off,rev it up and smoother it down with your hand over the carb till it nearly dies,remove hand and clean it out by reving it back up. I do this two or three times and it usually work good for clearing goo and trash out of the boosters,which is what's wrong with yours Caleb.
