DMan1198 wrote:Congratulations Caleb. From what one of my instructors at school said there's more cat service trucks in North America than there are cummins employees. Saying that my class has one finning guy, and 1 cummins guy
PToombs wrote:Why is every conversation normal and when Levi steps in it turns gay?
dazedandconfused wrote:Does anyone know if we have a 12V power source that only active while the engine is running? If not what is the easiest and safest keyed 12V source to grab power from? May finally get around to putting my lift pump on.
CumminsPower59 wrote:dazedandconfused wrote:Does anyone know if we have a 12V power source that only active while the engine is running? If not what is the easiest and safest keyed 12V source to grab power from? May finally get around to putting my lift pump on.
Easy, run a trigger wire from say....the fuel shut off circuit, to a relay, you could run it straight from the battery. Really any "key on" circuit should work. Put a relay and appropriate size automatic resetting two post circuit beaker and you'll be in business.
dazedandconfused wrote:Going on the Ford?
Tacoclaw wrote:PToombs wrote:Why is every conversation normal and when Levi steps in it turns gay?
Pete, Hiney, Zach, we now have to surrender our gay crown, scepter, and cape and ship them to Mississippi. There's a new king in town.
I saw Ellis using emojis on FB, it literally doesn't get any gayer than that.
Tacoclaw wrote:I've never used them, not even ironically. That should prove my disapproval.
I don't hate nissans, but the only real exposure I've had to them was an 80's 280zx (literally the sexiest thing on wheels) and my aunts old 90's Pathfinder which refused to die.
ellis93 wrote:Tacoclaw wrote:PToombs wrote:Why is every conversation normal and when Levi steps in it turns gay?
Is that what they are called? I didn't know that,guess you've used a few then huh?
How else can I call a Nissan a piece of schit.
