Philip wrote:His skid loader can do the second row.
Find a closed tandem trailer. Schilly uses spreads from what I remember. Tight turns you do local most of the time eats tires and bearings on spread axles.
In uneven ground backing a spread can be a pain if the trailer doesn't have a dump valve on it. It will turn on the axle with the most weight on it. If you setup for rear axle back in and it pivots on the front axle. Well time to reset for the front axle. Then most likely it will do the rear axle after respotting.![]()
At work for our storage trailers we do not use or buy spread axles. To much of a pain in a unimproved parking area.
RumbleFish wrote:So my manifold is shrinking. What should I replace it with? Stock? 3 piece? What brand?
CumminsPower59 wrote:Too bad D80's don't have 3.07's, I'd rather have one of them.
RCCUMMINS89 wrote:It stays in the outbox until I open it
PToombs wrote:RumbleFish wrote:So my manifold is shrinking. What should I replace it with? Stock? 3 piece? What brand?
You haven't decided on this yet?I thought you had it all figured out when I was there 3 weeks ago?
