diesel freak01 wrote:Ellis, try downloading tunein radio. You can normally find local stations or one that you like. Iheart radio is another ok one.
Tore the tractor down last night to fix an oil leaking head gasket. Turns out we got lucky and pulled it apart when we did. It was lifting the head and letting compression leak out. I guess 65 pounds of boost at 40 degrees of pump timing will do that. $1200 later studs new gasket and fire rings are on the way. Trying to have it back together by Thursday.
