CumminsPower59 wrote:If you can get it cheap enough, just swap in a D60 monobeam axle....?
cmann250 wrote:CumminsPower59 wrote:If you can get it cheap enough, just swap in a D60 monobeam axle....?
D60s are $1000+ around here and you dang near need a donor truck for springs, shackles, and such. Trust me, I've thought about it.
diesel freak01 wrote:Has anyone ever done dyno testing with water injection going from straight water to washer fluid? Having trouble getting the tractor to stay lot when the water comes on. Comes on good with the charger and then water comes and puts it out. Running three enderle alcohol injection nozzles, 700-750 psi, and about a pint and a half of water in 15 seconds. Any ideas? Thinking running straight washer fluid with oil may help but not 100%.
