Postby DMan1198 » Sun Aug 24, 2014 8:18 pm
I say do the 10. Mainly because the good tuning options are right there with no need to wait for anything before applying more powers of the horse
Postby DMan1198 » Sun Aug 24, 2014 8:37 pm
This is after I cleaned a bunch of it up, but the lower water line that you can see running over the oil cooler decided to wiggle loose over the 3 months it's been like that. Since I have zero bracing on that line it's kind of an inevitability that it'll happen again if I don't mid the line, and get it so there's more than a zip tie holding it. Ahh the joys of doing something different from a "kit"
Postby Tacoclaw » Mon Aug 25, 2014 6:58 am
My baby's first day of school. A solid pass so far, but we'll see if I make it home this afternoon. :lol:
Bone stock, I moved the linkage to the inside hole but haven't pulled the high-idle screw yet. It also came with pre-broken plastic rod ends, so I tied them together with tie wire. :grin:
Postby DMan1198 » Mon Aug 25, 2014 8:07 am
There you go. I'm pretty jealous of of you rc cummins guys. Maybe I'll do one one day
Postby DodgeFreak » Mon Aug 25, 2014 11:25 am
Got the trans in the 98 and took it down the road a 1/4 mile and on the way back it wouldn't build boost with a weirf whine....got back, pulled the boot off and sure enough the turbo took a dump....and when i shut the door the window fell down inside the door.......i dont think it liked sitting so long....lol
Postby ellis93 » Mon Aug 25, 2014 12:00 pm
DodgeFreak wrote:Got the trans in the 98 and took it down the road a 1/4 mile and on the way back it wouldn't build boost with a weirf whine....got back, pulled the boot off and sure enough the turbo took a dump....and when i shut the door the window fell down inside the door.......i dont think it liked sitting so long....lol
Damn plastic rollers,another stupid idea from the absolute worst company at buying plastics.
Postby DodgeFreak » Mon Aug 25, 2014 12:13 pm
Can you replace just the rollers??? Its been a good 7-8 years since ive been in one
Postby ellis93 » Mon Aug 25, 2014 4:09 pm
Not to my knowledge,I just get the new regulator w/ motor. I think there is about 20$ diff in the reg w/ motor and the one w/o.
Get this tho,the aftermarket I have received here lately had a square slider thingermabob instead of the plastic wheel. :lol:
Postby cmann250 » Mon Aug 25, 2014 4:22 pm
I hired in with a farmer today. My unemployment was brief :lol:
One day yellow equipment, the next green. This fall will be profitable.
Postby Tacoclaw » Mon Aug 25, 2014 4:51 pm
Turn out some wheels from brass, Zach. 8)
I weighed the RC tonight, 5680 with a full tank. What a porker. :?
This pig weighs as much as the Dodge with the Getrag. :lol:
I've been reading up on the transfer cases, I'll probably snag the 241 that came in the RC stock and swap it for the 205 I'm rocking now. Lose a few lbs and get the lower low range, it's apparently all interchangeable from the bolt pattern to the output splines.
Also, apparently you can use the trans mount from the RC's original drivetrain and it'll match your crossmember holes back up without redrilling. I'll give that a shot and report back as well.
I noticed the diesel mount's leg mounts about an inch farther towards the passenger side, maybe to give it more leverage against the engine?
Postby PToombs » Mon Aug 25, 2014 5:19 pm
Calebs working with the good Shit now! :lol:
Postby oldestof11 » Mon Aug 25, 2014 6:22 pm
Hey Pete, you see Green is installing Red in they're tractors?
Postby DMan1198 » Mon Aug 25, 2014 7:17 pm
So it turns out when I arced out a wrench during my 2nd gen swap I melted a hole in my passenger side battery. That might explain some of the harder starting possibly
Postby RCCUMMINS89 » Mon Aug 25, 2014 8:43 pm
Just did some test driving tonight.......yea, automatics SUCK. And oh, how I have missed common rail trucks. Still haven't found the right one though.
Postby DMan1198 » Mon Aug 25, 2014 9:27 pm
Custom tuning can make the automatics much better. Mine still pisses me off often, but it's better than when it was stock. If you decide on a manual a 2010 would be the best of the 4th gens
