Postby PToombs » Thu Sep 04, 2014 5:26 pm
dazedandconfused wrote:Glad to hear you got it Jon. Remember to use antiseeze when putting out back together
I don't think he's going to worry about taking it apart again. :lol:
Postby dazedandconfused » Thu Sep 04, 2014 5:47 pm
Probably not but helps with alignment in the future. 8)
Postby oldestof11 » Thu Sep 04, 2014 7:15 pm
After I got the bushings out, I see it has been "repaired" previously. So I am looking for another set of control arms.
Postby dazedandconfused » Fri Sep 05, 2014 4:40 am
What did they do to them?
Postby Philip » Fri Sep 05, 2014 5:21 am
Tacoclaw wrote:Talked to the gear dude myself today, he insisted that not only are the housings different but the gears themselves are and I need that 4.56 Detroit. I tried explaining the housing offset like 3 times, but they were insistent that the 3.54-4.10 gears had an offset built into them as well. :?
I sent Root a PM, I've done all I can do. :bom:
Just tell the D/A if he can't supply the correct part to refund the money. He doesn't know jack about a 3:07 axle.
Postby oldestof11 » Fri Sep 05, 2014 6:55 am
dazedandconfused wrote:What did they do to them?
Piece of flat stock, 1/8" or so, welded on the inside of the rear bushing area. Big hole drilled through. There isn't a "neck" on the outside of the A-arm, just a big washer.
Postby dazedandconfused » Fri Sep 05, 2014 11:55 am
Nice
Postby RCCUMMINS89 » Fri Sep 05, 2014 12:05 pm
2006 quad short, auto, silver, big horn.... The Hungry Diesel's new truck.
Postby DMan1198 » Fri Sep 05, 2014 12:23 pm
Pictures or it didn't happen
Postby RCCUMMINS89 » Fri Sep 05, 2014 12:53 pm
Signing papers tonight.... then going camping. It'll be Monday or Tuesday before pictures get uploaded.
Postby meby » Fri Sep 05, 2014 1:28 pm
Found a engine for my tractor. A friends dad had and old Mercedes diesel sitting around that he's going to give me. It will need a little work, but my Case is going diesel!
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby DMan1198 » Fri Sep 05, 2014 5:45 pm
So is it bone stock? And do you have a plan for upgrades?
Postby cmann250 » Sat Sep 06, 2014 3:00 am
I've been wanting a cushion hitch for some time since I pull a lot of hay wagons. It just so happened that a mechanic at Cat had one and didn't have a use for it. I didn't give much for it, but man oh man does it make a difference.
I have a used version of this :
Turns out that they are $500 new :shock:
Postby PToombs » Sat Sep 06, 2014 3:23 pm
Here's a pic of my $800 camper. I just remembered I had one. :lol:
Postby PToombs » Sat Sep 06, 2014 3:24 pm
Caleb, that's weird how it goes into the receiver. I've only seen them that are a complete hitch.
