Postby PToombs » Thu Sep 18, 2014 5:45 pm
Way closer, since he's driving 15 or 1800 miles to get there! :lol:
Postby DMan1198 » Thu Sep 18, 2014 8:14 pm
Made a new CCV vent tube since I found the old setup sprayed oil on my comp housing. Also aside from 2 nights I've loaded a new tune every night this week
Postby oldestof11 » Thu Sep 18, 2014 8:22 pm
At least you can see a valve cover, unlike the V8's.
Postby DMan1198 » Thu Sep 18, 2014 8:29 pm
It's still a total b!$&h to get at number 6 for a valve lash, and I put a hole in one back pocket in my jeans sitting in there working on it. First gens are way better
Postby Tacoclaw » Sat Sep 20, 2014 7:35 pm
Little status update on the RC, I pulled the high idle screw and moved the linkage to the inside hole, it's good to 90 with 33x12.50's. I haven't taken the slack out of the throttle cable yet, so there may be a bit more left in it. It was good enough for the hour or so I spent on the interstate today. :grin:
Mr. Always-leave-a-motor-mount-loose-Thompson did notice that I forgot to tighten the long bolts that go between the block and U-shaped piece of steel that sits on the motor mount. One is MIA and the other is hanging about 2" out of its hole, held in only by the weight of the engine wedging it sideways. Guess I'll fix that tomorrow. :lol:
Postby DMan1198 » Sat Sep 20, 2014 7:54 pm
That's a nice rc Levi. I drove The Roo Hunter for a while with the drivers side engine mount just like that for a while (probably about a month after I noticed it, and who knows how long before)
Postby Tacoclaw » Sat Sep 20, 2014 8:04 pm
It's pretty rusty, but oddly enough it's rusted in all the opposite places from the old Dodge.
I'm gonna hack the rockers off of it tomorrow. Start my own version of rust fixing.
Postby AHineman » Sat Sep 20, 2014 8:25 pm
Nice tires. Got 7 more waiting in my barn for you to pick up. :P
Postby oldestof11 » Sun Sep 21, 2014 5:00 am
An odd part of me wants a crew cab short bed and weld the rear section of a RC on to it to make a Dodge Suburban. Then I remember all I really have to do is buy a suburban and swap it. Lot less hassle.
Postby AHineman » Sun Sep 21, 2014 5:54 am
But then you've still got a Chevy.
Postby Tacoclaw » Sun Sep 21, 2014 7:02 am
Or just rock a normal RC, it isn't so bad as a 2-door. It would be nice if the driver's seat folded forward too, but I wouldn't make it any longer. The thing is basically a forklift with the wheelbase it has.
And yeah, Chevys suck.
Postby oldestof11 » Sun Sep 21, 2014 8:40 am
At least there's a whole gaggle full of parts available.
Postby cmann250 » Sun Sep 21, 2014 2:07 pm
Baled up 40 acres of 3rd cutting alfalfa this weekend.
Take that DOT :lol:
Postby Tacoclaw » Sun Sep 21, 2014 2:54 pm
I know it's a Ford and all, but I don't think the DOT will hassle you about it unless you don't get it completely off the road. :P
Started my rust "fix". A piece of 4" strap fits right up in the space left behind, so I'll weld one in there to stiffen the rocker back up. Bonus points that it got me some extra clearance around the front tire. I was having some interference already when it gets crossed up.
Postby oldestof11 » Sun Sep 21, 2014 3:37 pm
I like that!!!
I may be doing this to my truck to rid of some of the bad rust. $300 in rockers and floorboards...
