Postby Tacoclaw » Fri Oct 24, 2014 2:40 am
They slap themselves to make sure they're not dreaming.
Postby AHineman » Fri Oct 24, 2014 8:37 am
Postby DMan1198 » Fri Oct 24, 2014 11:36 am
Those farm implements must be transformers if they're slapping themselves
Postby meby » Fri Oct 24, 2014 1:15 pm
PToombs wrote:Anybody ever hear of a "farm special" made in the mid '90's? I was talking to a guy today who said he has one. It's a 3/4 ton truck with heavier driveline parts all thru it, wheel bearings, brakes, axles, etc. He said every time he needs parts he has to get them thru dodge or take the parts to be matched up.
Just wondering if anybody else has heard of one.
I don't know about a farm special, but dad's W 250 has some 350 parts on it.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby PToombs » Fri Oct 24, 2014 5:44 pm
Matt, that sounds like a more likely scenario to me too. I didn't want to argue with the guy, him being the customer and all. ;)
Postby cmann250 » Sat Oct 25, 2014 9:34 am
What I did at work today.
Postby dazedandconfused » Sat Oct 25, 2014 9:51 am
Hey Ellis any tips on putting a 350 in s square body S10? Brother started a new project today. He is putting a card vortec 350 in it. Are you angle to keep the AC?
Postby ellis93 » Sat Oct 25, 2014 2:34 pm
There are several things that you have to do to be able to run ac,especially if you want to keep the newer brackets and serpentine belts.
1 buy the short (car style) engine mounts for the engin side. Moroso (sp) makes some that I like
2 remove the rubber engine mounts from the frame and throw them away. This will let the motor set down and back enough to allow room for a long water pump and your brackets. For mounting the engine,I use a piece of black iron pipe(any kind of thick walled tubing will work) cut to fit tight in the engine mounts,weld it to the frame with a gusset from frame to under side of tubing. If I remember right,usually I find that about one inch of tubing sticks forward of the crossmember. That where the gusset comes in. I also add some to the top of the tubing,down the side. I've done 3 of these trucks like this and have never had any issues with this mounting. Also there will be ample hood clearance done like this.
3 I would recess the radiator into the core support to run a mechanical fan,there's nothing more reliable than a mechanical fan to me.....but I'm weird :lol:
I'll find some pics of my last one. It was a dd work beater for a while.
Postby ellis93 » Sat Oct 25, 2014 3:08 pm
Tbi motor with throttle body spacer and the z71 air cleaner,hood still had room to close
Look at the room with the rad recessed
That's the brackets/serp setup from a 94 z71. It doesn't look like much but it was all just crap I had laying around. After the 2.8 died at 280k I wasn't just gonna throw the truck away.
Postby dazedandconfused » Sat Oct 25, 2014 4:58 pm
This one has a rod knocking 2.5 in it. He has a 90% rust free bed, doors and fenders. What did you do for exhaust manifolds?
Postby PToombs » Sat Oct 25, 2014 5:23 pm
Looks like small tube headers in the pic.
Postby ellis93 » Sat Oct 25, 2014 5:28 pm
Pete has it right. Best ones to get are headman headers made for this swap. 3/8 flangs with ball flang collectors. No leaks,no pita gasket changes. They're shorties tho,long tubes are a bad idea on these trucks because of the way the frame necks around the trans.
Postby fatty » Sun Oct 26, 2014 1:02 pm
I was driving yesterday and noticed a mouse playing around on the pass side floor. Didn't think too much of it, until his buddy joined in the frolicking. Then I got annoyed and managed to chase one out. Far as I know the other one is still there. Going to put a trap today, but I don't even know how they got in there...
Postby oldestof11 » Sun Oct 26, 2014 1:58 pm
Fatty, I had one of those once in my burnt up 4x4. Except he made it apparent when he ran up my pant leg to my family jewels. :lol:
Yes, I screamed. Yes I pulled over and did the chicken dance. No, I didn't kill him. :shock:
Postby PToombs » Sun Oct 26, 2014 4:32 pm
oldestof11 wrote: Except he made it apparent when he ran up my pant leg to my family jewels. :lol:
Jon, I think you altered that statement from what really happened. Just admit it was really a gerbil and we won't need to go any farther......... ;)
