762frmafr wrote:My impression of these trucks was that being all mechanical, they would be "tougher" than this. I was figuring they would chew up and spit out a bit of old fuel. Is there any option in a lift pump I can install that will be more durable?
CumminsPower59 wrote:No base, its an inline strainer, very similar to an universal gasoline filter. Uses 3/8" inlet and outlet. Worked well for me since I upgraded the fuel supply and return lines to biodiesel compatible rubber line, an inexpensive upgrade in my opinion.
PToombs wrote:Too bad you didn't see my post above before you ordered them, I only get on once a day so I couldn't warn you sooner.
CumminsPower59 wrote:Apologies, I should have double checked before I posted...
RCCUMMINS89 wrote:Will an i/c grill fit a non i/c core support?
lz69 wrote:RCCUMMINS89 wrote:Will an i/c grill fit a non i/c core support?
From what I have read they have the headlight buckets in different locations. Remember seeing pictures where the owner cut up the core support and relocated them to match the different grill
