w150 6bt
w150 6bt
Postby Loaded burrito » Wed Nov 19, 2014 10:05 pm
i looked into doing this conversion a few years ago.. and i sold the project... for some reason there was quite a bit of good information and now it disappeared or i for some odd reason cant find it.. i would like to discuss this with people that have done it or know someone that has done it.. how is the 1/2 ton axles holding up? did the gas tcase bolt up? anything yall would like to share? i know there are guys with 4x4 1/2 ton cummins running around. thanks
Loaded burrito
Re: w150 6bt
Postby CumminsPower59 » Thu Nov 20, 2014 7:54 am
I sold my pristine 85 W150 a few years back, was going to be a 4bt. I know the half ton axles and suspension can deal with the weight of a 4b, seeing its comparable to a 440. Now, I wouldn't use the half ton axles or suspension with the added 300+lbs of a 6bt, may be a bit too much weight for the lighter capacity springs and smal ball joints. It may be plain easier to use a complete donor, that way the stronger D60F and D70 are used, same with transfer case. Not sure how well or how long the gasser NP208 would hold up. The 4b W150 I was going to build was going to use all W250 drive train components, just swap drive train components, wiring, fuel system and go.
Re: w150 6bt
Postby dazedandconfused » Thu Nov 20, 2014 5:06 pm
I have a short bed D150 Cummins truck. It will be going back to a gas truck and going 4x4 soon. I've done the half ton gas thing and grew tired of it. Truck is to big of a pain in the ass to daily drive in the rain.
Re: w150 6bt
Postby Loaded burrito » Mon Dec 01, 2014 8:06 pm
I'd love to see your truck Daze.. I am from Kentucky myself
Loaded burrito
Re: w150 6bt
Postby dazedandconfused » Tue Dec 02, 2014 12:19 am
It won't be diesel for much longer. Its going back to a 318. What part of my are you in?
Re: w150 6bt
Postby Loaded burrito » Tue Dec 02, 2014 4:31 am
Bardstown.. And why.. Do you need another engine?
Loaded burrito
Re: w150 6bt
Postby dazedandconfused » Tue Dec 02, 2014 1:48 pm
The truck is just too nose heavy and I need that engine for my crew cab Ford. I have a low mile 318 engine and trans from a 92 to go in it.
