DMan1198 wrote:Just make sure you do the flexplate at the same time as the converter. A friend of mine didn't, and then his flexplate sheared around the flange. It actually cracked the adapter plate.
Fly cuts won't be too bad. How much are you guys having to take off?
RCCUMMINS89 wrote:Depends what I'm feeling when I do it.
When it gets a trans... it'll be an 800+hp trans. Dave Goerend, or Firepunk will most likely be in it. Dave, being such an amazing guy (customer service is unheard of)... I'll most likely be using all of what HE recommends. Which if that is the case, I may just do it myself (he says it's not that hard).
matthewh wrote:Anybody ever mess with bronze bushings, in relation to leaf springs? Took the front springs out of the M37 to get them re arched and 2" lift added, and the bushings are bronze, not rubber. Naturally there worn out like everything else, but I'm wondering best way to remove them? I've got 2 springs and the frame point to do.
Is thus as simple as a hammer and drift, or am in need of some type of press?
