Resurrection of the dodges paint And back to stock power
both inside and out
Postby ellis93 » Mon Dec 01, 2014 6:32 pm
So this all happened last year and I found it after that freakish ice storm crap we had. Apparently water had been sitting under the paint and when it froze it busted the bubble that was there.
And I've been battling this schit since I've owned it.
This will be either an epic failure or a deserved refinish for a hard working mule. Either way this is the last damn time I mess with the paint on this truck :lol:
Re: Resurrection of the dodges paint. Oh Boy
Postby fatty » Mon Dec 01, 2014 8:30 pm
Post lots of pictures of your progress. Hopefully it will motivate me to take care of my peeling paint before it gets too bad to fix.
Postby TheSilverBullet » Mon Dec 01, 2014 8:46 pm
My buddy's 92 is just roofing tar from one side to the other lol. No leaky leaky :D
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Re: Resurrection of the dodges paint And back to stock power
Postby ellis93 » Fri Jan 02, 2015 2:08 pm
Went ahead and decided to kill the power some more.....plus I need the thing where it's not slowly killing itself. I owned this truck for 10 years before having any issues and since I've messed with it I keep having problems. Mostly small stuff...several ujoints,head gasket,clutch....I'm tired of it. It's going back working class. Stock low mileage pump,lightly ground pin,hungry diesel afc spring/12psi hplp spring (no mo clicking reg). Also throwing in a new old stock cummins pump gear(had some issues with the old one walking on the pump shaft) timed back stock. No more high timing,just the 1/8 bump.
Still has the goo on it
Hardly ground pin
Funky springImage
Supply pump spring
I might get finished today
Postby ellis93 » Fri Jan 02, 2015 2:09 pm
Guess I should have relabeled this tread back to stock-ish power.
Postby ellis93 » Fri Jan 02, 2015 2:26 pm
This "good pump",ain't worth a damn. Leaks fuel and won't send diesel down one injection line. FML
Postby CumminsPower59 » Fri Jan 02, 2015 2:42 pm
ellis93 wrote:This "good pump",ain't worth a damn.
Experienced the same thing when I bought a N.O.S. 205 pump....gutless wonder compared to my worn out 114 pump. Had to screw the fuel screw in quite a ways just to get the darn thing to fire, then was still a turd after a lot of tuning.
Postby cmann250 » Fri Jan 02, 2015 2:48 pm
My Dodge must have had a special blessing on it. The closest thing I had to driveline trouble was a ballooned quarter million mile converter. I had every fluid except gear oil leaking, but nothing major. Ever.
Glad to see one being treated with the respect it deserves 8)
Postby ellis93 » Fri Jan 02, 2015 4:03 pm
Whatever was phucked up in the pump straightened out and now it's sending fuel. Still slobbering diesel tho,I've got another but I swear I don't want to mess with another used pos pump. Guess I'm going to "reseal" it.....non intercooled pump.
Wonder what kind of hell I'll find swapping delivery valves out between I/c and non i/c pumps?
Postby CumminsPower59 » Fri Jan 02, 2015 5:01 pm
There really isn't much going on with the delivery valves, just the holder, the valve assembly, a spring, sometimes a shim and a copper crush washer against the head. Pretty easy to swap, just really small parts.
Postby ellis93 » Fri Jan 02, 2015 5:09 pm
Ike does the non intercooled pump really throw that much more fuel/more responsive?
Postby dazedandconfused » Fri Jan 02, 2015 5:10 pm
Dam and I thought my old cab had windshield rot.
Postby ellis93 » Fri Jan 02, 2015 6:48 pm
dazedandconfused wrote:Dam and I thought my old cab had windshield rot.
It ain't scrap it bad tho....well,with the pump thing it nearly is. I almost want to drive this bitch over the scales. 300$ pissed away
Postby CumminsPower59 » Sat Jan 03, 2015 11:23 pm
ellis93 wrote:Ike does the non intercooled pump really throw that much more fuel/more responsive?
In my limited experience, yes. I'm about ready to do a rebuild on two pumps, a 205 and a 114 . I'll be doing side by side comparisons on certain important parts, I've heard that there is a definitive reason why the 103/114 pumps fuel a little harder at first than the 184/205's, and I want to see for myself.
Postby DMan1198 » Sun Jan 04, 2015 4:38 pm
So since this is still something I have learned. How do you tell what designation the pump is (205, 114, etc)?
Return to Body
