A runaway kind of situation...
Postby meby » Fri Jan 30, 2015 2:27 pm
I had a runaway engine yesterday. I got the air shut off before major death and destruction, but i'm pretty sure I floated some valves. When I crank it over it sounds normal, but as soon as it fires it makes an awful racket.
Where is a good source for head gaskets, valves and such? Should I replace or reuse head bolts? And is the removal and replacement procedure the same as the 2nd gen trucks? (I own a factory shop manual for a 2nd gen)
Thanks,
-Matt
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: A runaway kind of situation...
Postby fatty » Fri Jan 30, 2015 3:00 pm
Mumau diesel has great prices on Cummins parts. I would reuse the stocks bolts if you're not going too wild with the engine.
Postby meby » Fri Jan 30, 2015 3:33 pm
fatty wrote:Mumau diesel has great prices on Cummins parts. I would reuse the stocks bolts if you're not going too wild with the engine.
thanks,
bone stock now and will probably stay that way.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Fri Jan 30, 2015 6:33 pm
Matt, check the pushrods 1st before you get too excited, maybe it only bent some. And the 2nd gen manual should be close enough to pull the head if necessary.
Postby RCCUMMINS89 » Fri Jan 30, 2015 6:55 pm
Make sure you check the stock bolts (check the length) if you do end up pulling the head.
Postby meby » Fri Jan 30, 2015 7:06 pm
PToombs wrote:Matt, check the pushrods 1st before you get too excited, maybe it only bent some. And the 2nd gen manual should be close enough to pull the head if necessary.
Okay.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Fri Jan 30, 2015 7:08 pm
RCCUMMINS89 wrote:Make sure you check the stock bolts (check the length) if you do end up pulling the head.
To see if they are stretched? What length should they be?
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby RCCUMMINS89 » Fri Jan 30, 2015 7:17 pm
Not sure, but I know when I checked my original ones way back in the day... IIRC only 3 or 4 were within spec.
Postby DMan1198 » Sat Jan 31, 2015 3:20 pm
A top end kit should come with a stretch gauge. If the bolts are within spec they're good to be reused.
Postby oldestof11 » Sat Jan 31, 2015 5:18 pm
When I got a headgasket kit from Mumua, it had a stretch gauge in it. All of mine came back within specs with a 1/4" to spare.
Postby jethro » Wed Feb 04, 2015 11:19 pm
Do we need to start watching the pictures on the milk cartons for you ????????
(a joke!!!!!)
Tim
jethro
Postby DMan1198 » Thu Feb 05, 2015 8:46 am
Did you ever get a line on a ranger, and genset like you were talking about at SOP?
Postby meby » Thu Feb 05, 2015 5:51 pm
I've got an eye peeled but nothing serious yet.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby DMan1198 » Thu Feb 05, 2015 7:36 pm
If I've still got it around sop I could bring a little diesel genset for you. It'd need to be gone through, but I wouldn't ask anything for it
Postby meby » Fri Feb 06, 2015 5:24 pm
Thanks, I'll keep that in mind.
-Case 530 CK
www.ebyfarmsllc.com
meby
