door latch
both inside and out
door latch
Postby greasemonkey » Sat Mar 01, 2008 9:21 pm
right door has been having issues staying latched and finally gave up altogether. I took the latch out and cleaned all the grease/dirt buildup out and it helped. problem now is there's a plastic piece that's broken. long story short, I can put it back in and will be able to close/open the door but will not be able to lock it.
where do I find a door latch? will Dodge still have that or do I have to look at Napa or somewhere else? and does anyone know what year this latch will go back to for cross reference? I'll check on monday with my local dealer, they're pretty good about being able to find stuff and we get a business discount.
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby Philip » Sat Mar 01, 2008 9:24 pm
The plastic latch rod catch should still avaible from the dealer. It was used on many year models. That part hasn't changed much over the years.
Postby PToombs » Sun Mar 02, 2008 7:45 am
I think you can get that rod catch at most auto parts on the "Help" rack too.
Postby GO OVRIT » Sun Mar 02, 2008 11:35 am
https://www.dodgeparts.com/index.php I think it was wannadiesel that posted this link on another site. They should have what you need.
GO OVRIT
Postby CAJUN 93 » Mon Mar 03, 2008 7:20 am
the rh latch is part#55075872 list $114.00 trade$91.20 plenty of stock still available. it shows to fit 85 to 97 on trucks and some full size vans. shouldn't be too hard to find.
daryl
CAJUN 93
Postby greasemonkey » Mon Mar 03, 2008 9:10 am
GO OVRIT wrote:https://www.dodgeparts.com/index.php I think it was wannadiesel that posted this link on another site. They should have what you need.
found that thread by wannadiesel, that's a pretty good parts source...I'll have to remember to check for stuff there before I go in to the parts dept, they really like when I have a PN available and just have to verify it there instead of looking it up.
for now, I just left the lock rods off so I can use the door, just can't lock it. driver's latch is pretty worn, along with the hinges...I have some fun door rebuilding in my near future!!
greasemonkey
Return to Body
