Help: VE pump installing fass
Postby 93cummins89 » Wed Nov 04, 2015 6:25 pm
im installing a fass and im at the point of reinstalling the inlet parts for the fass on the VE but i cant get a wrench on the new fass fitting with out hitting the pump then i cant get a turn on the adapter. any helpful hint would very greatly appreciated.
93cummins89
Re: Help: VE pump installing fass
Postby thrashingcows » Wed Nov 04, 2015 9:04 pm
Are you talking about the FSS...(Fuel stop solenoid) ? If you are then you can trim off the top of the mounting bracket....not really needed, and it gives you a lot more room to mess with the FSS. :? :D
thrashingcows
Postby fatty » Wed Nov 04, 2015 9:20 pm
I think he means FASS(fuel air separation system) lift pump. I had that same issue when I put my airdog on and I ground a wrench thinner around the jaws until it worked.
Postby PToombs » Thu Nov 05, 2015 5:17 pm
Do you have 1 fitting or 2? Pretty sure there should be 2, an adapter that goes into the pump, (use a socket) then a swivel 90* that screws on to that. You can use a regular wrench on the swivel because the adapter raises the other fitting above the obstructions. IIRC.
Postby 93cummins89 » Thu Nov 05, 2015 7:08 pm
yes a FASS. i cant get wrench on the adapter. never thought about grinding down a cheap-o wrench. thought a flare wrench would work but i haven't tried that yet
93cummins89
Postby CumminsPower59 » Tue Nov 10, 2015 6:04 am
Take a picture of what you are trying to do so we can get a better idea of what you are trying to accomplish.
I can't see how you are having trouble with getting a wrench on the fuel line...but here's one for ya, why not pull the throttle assembly off the top of the pump? There shouldn't be a need for a flare wrench or anything special, those fittings aren't supposed to be gorilla tight anyways.
