Just got my oil sample back...
Postby t_ruffcorn » Wed Jan 06, 2016 8:59 am
I Just received the report on my oil sample and it was less than ideal. They go on a severity scale of 1 to 4 with 4 being classified as criticical, they flagged the level of aluminum at 10ppm citing piston wear assigning it a 4, and noted high sodium, citing coolant consumption or enviornmental contamination. It uses no coolant. So maybe a slight oil cooler weep? I haven't reached the post count to put a picture up of the report but I will once I can. Anyone else oil sample and have some numbers to compare with?
1993 w250 280k, 5 speed, 6x13 @80lpm, BD pin, 63/68/.80, 4200 gov, fluidampr, studs, springs, pushrods, 182/214 hamilton, W/M, steedspeed, PS I/C
t_ruffcorn
Re: Just got my oil sample back...
Postby BC847 » Wed Jan 06, 2016 9:16 am
Post your pic now. ;)
Postby t_ruffcorn » Wed Jan 06, 2016 9:25 am
Thank you sir. Image
t_ruffcorn
Postby RCCUMMINS89 » Wed Jan 06, 2016 5:53 pm
I've come to the point where I honestly don't care about parts wearing out........ they either work, or they are shot. That's how I get through destroying my own engines.
If it doesn't have so much blow by it is constantly puking oil..........screw it. Run the crap out of it.
Try to kill it and you'll find yourself proud that it keeps going. Wanting it to be healthy, and you'll find yourself always sad it is going down hill.
Postby 1320Fastback » Wed Jan 06, 2016 6:11 pm
I may be not seeing but what oil and weight are you using?
What filter also?
92 D250, Getrag 5 Speed, 3.54, extra cab, long bed, AC works, Airbags.
1320Fastback
Postby t_ruffcorn » Wed Jan 06, 2016 10:14 pm
15w40 and a fleet guard stratapore
t_ruffcorn
Postby t_ruffcorn » Wed Jan 06, 2016 10:16 pm
RCCUMMINS89 wrote:I've come to the point where I honestly don't care about parts wearing out........ they either work, or they are shot. That's how I get through destroying my own engines.
She burns no oil and has next to zero blow by. It runs so hard you'd swear it was a new engine. It's definitely gong to get put through its paces this summer on the strip and pulling track
t_ruffcorn
Postby jerseybud » Fri Jan 08, 2016 6:00 pm
If it was coolant contamination your bearing wear metals would be high too. But copper, lead and tin are normal with your sample. Other than the pistons, the next source likely is the turbo cool side- think bad bearing there or lack of oil supply or something got coked up?
1993 W250 a518 3.54LS. Has a hx35. Needs a beefed tranny
jerseybud
Postby t_ruffcorn » Sat Jan 09, 2016 9:23 pm
jerseybud wrote:If it was coolant contamination your bearing wear metals would be high too. But copper, lead and tin are normal with your sample. Other than the pistons, the next source likely is the turbo cool side- think bad bearing there or lack of oil supply or something got coked up?
That is exactly what I thought. Turbo has probably 15,000 miles on it. So almost has to be a piston
t_ruffcorn
Postby spencerdiesel » Sat Jan 09, 2016 10:22 pm
Is it the # 6 piston that runs the hottest?
