1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby spencerdiesel » Thu Mar 31, 2016 6:37 am
Looks good
Postby 79Powerwagon » Thu Mar 31, 2016 6:00 pm
Got the downpipe finished. Rigged up a temporary boost gauge. Definitely pulls harder all around. The turbo really sings.
Clamped the wg line just for chits and saw 40 psi with a blip of the throttle in OD.
79Powerwagon
Postby spencerdiesel » Thu Mar 31, 2016 6:05 pm
What speed is that cruise boost at?
Postby 79Powerwagon » Thu Mar 31, 2016 6:13 pm
65-70 with several hundred lbs of junk in the bed
79Powerwagon
Postby spencerdiesel » Fri Apr 01, 2016 4:52 am
Still aiming to NV swap it?
Postby 79Powerwagon » Fri Apr 01, 2016 6:06 am
Yes, I'd be happy with a getrag too. Really just want direct drive, no slip. And better mpgs. I could get a better converter but it seems I could do a 5 spd for just a bit more $
79Powerwagon
Postby spencerdiesel » Fri Apr 01, 2016 6:23 am
You know the going rate for used 4500's? Ill eventually swap as well
Postby 79Powerwagon » Fri Apr 01, 2016 6:35 am
Around here 1200-2000 for complete swap. Hoping to stumble on one a bit cheaper.
79Powerwagon
Postby 79Powerwagon » Fri Apr 01, 2016 8:33 am
I picked up this 77 Warlock a few weeks back. Cab is rotted. Missing interior. No title. Thinking on swapping the stepside bed, doors and fenders onto the 79 but I can't decide if I like the macho or warlock look better. Any opinions?
79Powerwagon
Postby 79Powerwagon » Sun Apr 03, 2016 10:30 am
Here's a few better pics of the he.
79Powerwagon
Postby spencerdiesel » Sun Apr 03, 2016 1:46 pm
Honestly I like the power wagon. Maybe nab some cool interior stuff out of the warlock
Postby 79Powerwagon » Sun Apr 03, 2016 3:39 pm
spencerdiesel wrote:Honestly I like the power wagon. Maybe nab some cool interior stuff out of the warlock
Only thing left is the factory tuff steering wheel.
Cleaned up the dash a bit. Custom 4X4 shift knob courtesy of a 1973 Kawasaki 175 dirtbike.
79Powerwagon
Postby spencerdiesel » Sun Apr 03, 2016 5:32 pm
Hey I like those pedals!
Postby 79Powerwagon » Tue Apr 05, 2016 7:48 am
Starting to collect parts for the hp buildup. I want it to be 450-500 hp capable.
Think I'm going to run 12.9 socket head headbolts. Anyone with first hand experience there?
Going to have head milled, these usually need valve job/guides around 300K miles? Thinking it wouldn't hurt.
60 lb springs and 366 gov going in also. Looking at 6X13 injectors.
79Powerwagon
Postby spencerdiesel » Tue Apr 05, 2016 9:13 am
Where you getting your sticks from?
