1990 d350 transmission swap
Postby Dirty Luther » Wed Apr 06, 2016 9:28 pm
I will be eliminating the 727 replacing it with the g360 also taking out the 307 rearend replacing with 354s
I've gathered all the parts necessary to do the job. Atleast I think I have . Is there anything in particular I should be watching for or any problems that could occur throughout this install.. Please share your knowledge. Thanks
Dirty Luther
Re: 1990 d350 transmission swap
Postby CumminsPower59 » Thu Apr 07, 2016 10:19 am
Have you got a different transmission tunnel to screw or weld in? The "D" series with automatics have a smaller transmission tunnel, all manual trans and all "W" series have a larger tunnel...
Postby Dirty Luther » Fri Apr 08, 2016 2:19 pm
Is it possible to run 307 gears. If I wasn't going to pulling anything..
Dirty Luther
Postby Philip » Fri Apr 08, 2016 2:49 pm
Dirty Luther wrote:Is it possible to run 307 gears. If I wasn't going to pulling anything..
Yes it is. 3:07's are a good road gear. High MPH with lower engine RPM = less noise.
I have driven long distance with 3:54's. That's why a friend of mine needed to make a long trip we took my truck. 3:54's at 70 MPH is loud.
Return to Transmission
