1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby PToombs » Sun Apr 17, 2016 4:37 pm
Thanks for the tips, I'll pass them on. I think it's a 3/4 ton but back then the frames were the same.
Postby 79Powerwagon » Mon Apr 18, 2016 8:55 am
No problem. Also I just used factory 93 engine mounts.
No more stack and original doors back on. They still need patch panels.
79Powerwagon
Postby 79Powerwagon » Mon May 02, 2016 10:23 am
Wannabe
79Powerwagon
Postby dazedandconfused » Mon May 02, 2016 10:50 am
My turndown rattles my brain in my truck. What do you have now that you ditched the stack?
Postby 79Powerwagon » Mon May 02, 2016 10:58 am
I'll get some better pics but just a 5" over axle dump.
It's better but still loud. Have a ton of noise coming through the firewall. I may stick the silencer ring back in the HE351.
79Powerwagon
Postby 79Powerwagon » Mon May 02, 2016 11:00 am
Cobbled together out of an old y pipe off a 375 pete
79Powerwagon
Postby dazedandconfused » Mon May 02, 2016 11:19 am
Mine is close to the ground so it drones bad all the time.
Postby PToombs » Mon May 02, 2016 3:11 pm
Turn it out or continue it out the back. Nothing says BAD like a 4 or 5 inch pipe coming out under the bumper. ;)
Postby 79Powerwagon » Mon May 02, 2016 4:36 pm
PToombs wrote:Turn it out or continue it out the back. Nothing says BAD like a 4 or 5 inch pipe coming out under the bumper. ;)
That's my plan once I round up some more old 5" pipe 8)
79Powerwagon
Postby 79Powerwagon » Wed May 04, 2016 1:21 pm
Keep dreaming about the warlock utiline bed on this truck. Think I may swap it out.
79Powerwagon
Postby dazedandconfused » Wed May 04, 2016 1:42 pm
I've been trying to find one of those for years now. All too far away
Postby 79Powerwagon » Sun Aug 07, 2016 2:28 pm
Been DDing this thing for the past few months. Leaf spring bushings are starting to crumble. Quick fix was a chunk of dayco heater hose over the sleeve...
Hyperflex poly kit & greasable bolts on order :)
79Powerwagon
Postby 79Powerwagon » Thu Aug 11, 2016 6:36 pm
Some work done tonight..
Ended up making greaseable bolts.
79Powerwagon
Postby 79Powerwagon » Thu Aug 25, 2016 8:09 am
Here's a question....
I come across quite a few mid size CAT turbochargers, mostly s300, have two with 66 compressor wheels. Not sure on exhaust as housings are a bear to get off. T4 foot, one is gated.
Being that this truck weighs in around 5700 lbs and has a sloppy converter, would I be any better off trying to get a 66 spooling?
79Powerwagon
Postby 79Powerwagon » Sat Aug 27, 2016 5:59 pm
Got a hold of a good one I think....
66 comp wheel. Variable vane. Need to heat the ex housing and measure the turbine. Now I need to make a t3/t4 adapter or get a t4 manifold...
79Powerwagon
