Getrag clutch question.
Postby Ramcharger87 » Wed Feb 08, 2017 3:48 am
Hi all. So I'm SLOWLY getting my 87 Cummins Ramcharger put together. I procrastinated long enough on buying a low-stall converter for the a518, that I stumbled onto a good Getrag 360 / 205 combo.
My question is, is there any reason NOT to use a basic replacement clutch set, like a Luc for example. The engine is in the 200hp - 500lb-ft range and the vehicle itself is light compared to a W350.
I have no issue running a South Bend or similar brand on high horsepower applications but Rock Auto has some killer prices on "stock replacement" clutch sets (under 3 bills for clutch set AND flywheel).
1987 Dodge RamCharger, 1-ton axles, 4-inch suspension lift, 35's and soon to be, a 1993 5.9L CDT / Getrag 360 / NP-205 combo.
Ramcharger87
Re: Getrag clutch question.
Postby oldestof11 » Wed Feb 08, 2017 6:07 am
Do NOT use Luk. Get a stock 13" Sachs or go straight to Southbend or Valair.
The "upgraded" 12.25" Luks have a problem tearing the center out.
Postby Ramcharger87 » Wed Feb 08, 2017 12:37 pm
Who carries Sachs anymore??
I just visited Valair's site. Says they don't offer a Getrag replacement clutch anymore. 12.25" 4500 retrofit or 13" 4500 upgrade only.
Ramcharger87
Postby oldestof11 » Wed Feb 08, 2017 4:19 pm
Call Dan Valance @ Valair. The NV4500 1-14" input clutches should fit.
Postby PToombs » Wed Feb 08, 2017 5:11 pm
X 2! They can build any clutch you want. I have the 650hp ceramic which uses a NV5600 flywheel and have the stock Getrag. All they did is put the Getrag center in the ceramic disc.
Postby Ramcharger87 » Thu Feb 09, 2017 2:12 am
So I contacted South Bend Clutch via email. Instead of Peter, i hear back from
MANSEIL WASHBURN, who is apparently the diesel manager now. I explained it is a bacically stock engine (200hp - 500lb-ft) in a lighter-than-stock vehicle. 4.10 gearing turning 37" tires. 4000lb max expected towing with possible moderate off-roading or back-country camping in the future. He "recommends" their new $1200 (not including flywheel) dual-disc street clutch!
I hope Peter is still around somewhere, cause this Manseil seems out of touch with what their customers need.
Ramcharger87
Postby oldestof11 » Thu Feb 09, 2017 4:20 pm
Call Dan at Valair. Trust me on this.
Dan will tell you not only is over-powering a clutch bad, but so is under-powered. Under-powered trucks tend to slip it more on take off or towing because it is so grabby.
I bet a 13" organic with 3600lbs pressure plate would be perfect.
Postby Ramcharger87 » Fri Feb 10, 2017 11:36 pm
Thanks to everyone for their input. I was able to locate a stock 13-inch Sachs today at Rock Auto (the last one they had in stock!). I was hoping to snag a Sachs flywheel while i was at it but someone beat me to the last one by 2 hours.
I had gotten a Sachs flywheel and clutch assmbly with the trans, so i just took the flywheel to the local machine shop for resurfacing. The guy behind the counter was impressed with the appearance of the flywheel and barring anything evil (like a crack) feels it should clean up with no more than .010" removed.
Ramcharger87
Postby Philip » Sat Feb 11, 2017 6:47 am
Ramcharger87 wrote:I hope Peter is still around somewhere, cause this Manseil seems out of touch with what their customers need.
Yes he is. I talked to someone there a while back about a new clutch for my truck. For a single disk non-performance stock rated G56 clutch it was $900 without hydro's. Valair was $699 with hydro's.
I now have a Valair in my truck. The price difference payed for someone to install my clutch.
Return to Transmission
Users browsing this forum: No registered users and 81 guests
