Over under vs side by side
Postby 2uphill » Tue Jan 22, 2019 9:43 am
Ok so I have been contemplating compounds for sometime, searching some old threads, and reading/talking to various companies who have built compounds for first gens trying to learn advantages/disadvantages of the two choices considering the limited room we have to encounter with heater, front diff,transfer case, etc.,etc.,....SOOO, those of you who have them what are your thoughts?.?
90 d350, SRW, 2wd, 727, stock, except banks i/c, 85K
84 w350 crew cab, I/c 89, s300, 727, 4x4, 130K
90 w350cc, 3.54, getrag, 125K
82 d350 crew cab project
2uphill
Re: Over under vs side by side
Postby 2uphill » Tue Jan 22, 2019 9:46 am
Oh yeh I have the s300/S400 ready to attempt sometime this year...
2uphill
Postby DMan1198 » Tue Jan 22, 2019 12:25 pm
I built side by side for mine. Everything fits with plenty of room, I can get the oil filter out with everything in place, only thing I had to move was the washer bottle, and I can pull the whole setup apart in about a half hour.
Postby PToombs » Tue Jan 22, 2019 5:03 pm
I did side by side on mine, biggest problem is fitting a large enough air filter in there. My washer bottle is MIA at the moment, I haven't finalized my filter set-up yet.
Postby 2uphill » Tue Jan 22, 2019 9:48 pm
Thanks, Did you have to use 1” spacer off exhaust
2uphill
Postby BC847 » Wed Jan 23, 2019 11:03 am
I've done both.
First with an HT3B under an S363 (as under/over), then triples (has both under and side mounted)
Had to relocate the transmission fluid heat-exchanger to put stuff down there.
Meh, both arrangements have pluses and minuses.
- Having the primary under the secondary may make the exhaust down-pipe less complicated but then the trans heat-exchanger's in the way. If you've a manual trans, that's not an issue.
- Having the primary out to the side may make routing an air-filter feed difficult.
It's been my experience that either way, making the hot/cold plumbing compact is the real stick-in-the-mud as it were.
Postby 2uphill » Wed Jan 23, 2019 2:11 pm
Thanks, I think I saw your thread on triples ( or someone’s )..I appreciate the heads up of what to expect and results of choices you are going to live with...does ex man need to be turned up or everything as is?
2uphill
Postby PToombs » Wed Jan 23, 2019 6:12 pm
2uphill wrote:Thanks, Did you have to use 1” spacer off exhaust
I don't remember! :lol: Pretty sure the small turbo is right on the manifold.
2uphill wrote:does ex man need to be turned up or everything as is?
I flipped mine up.
Postby 2uphill » Thu Jan 24, 2019 8:04 am
Thks you guys , really appreciate it.
2uphill
Postby DMan1198 » Mon Jan 28, 2019 12:30 pm
If you flip the manifold, run the secondary facing forward, and point it’s outlet down you need at minimum a 1/2” spacer. If you’re ok with a complicated secondary to ic pipe then you don’t need a spacer, or if you face your secondary backward you don’t need one unless you keep the manifold facing down.
My mess is manifold up, 1/2” spacer, both turbos facing forward. All 4” piping except secondary to ic.
Postby PToombs » Mon Jan 28, 2019 6:00 pm
Ahhh, that's why! I flipped my manifold and the small turbo faces backwards.
Postby 2uphill » Tue Jan 29, 2019 12:43 pm
Does that help you go faster in reverse.. ;)
2uphill
Postby PToombs » Tue Jan 29, 2019 4:51 pm
2uphill wrote:Does that help you go faster in reverse.. ;)
Wellll yeah! Ram air kicks in that way! :lol:
Postby Donkey Kong » Fri Feb 01, 2019 7:27 am
When I first read the title I thought this was going to be about shotguns.
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Postby PToombs » Fri Feb 01, 2019 5:36 pm
Donkey Kong wrote:When I first read the title I thought this was going to be about shotguns.
Me Too! :lol:
