Hey guys new intake In R &d on the Cummins forum
Postby roxxx » Wed Jun 04, 2008 9:19 am
here is the link i have already put in dibs on testing first gen intake but i think i live to far away to get considered
http://www.cumminsforum.com/forum/98-5- ... ifold.html
anyone in the Van Nuys CA area ever here of this shop AirForce One Performance. I talked online to Mopar man from the cummins forum he said these guys are fabin up some intakes. he wasn't to sure if the 1st gens were on the build list ...if some one is in that area they should swing by and see
<edit> hey folks Not trying to step on anyones toes here just stumbling around on the net trying to help sorry if i have. plus Please be careful on the cummins forum there is a fine line between helping and advertising . which I am not I have no connection to this shop just trying to find a cool air intake
thank you
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby seeker1056 » Wed Jun 04, 2008 1:40 pm
already have one - a prototype that i bought off Ebay
this one looks like an exact copy of mine except mine has a bead rolled in the end of the tube to help retain the hose
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby CumminsPride » Wed Jun 04, 2008 3:40 pm
Looks familiar huh Swank and Tim?
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby TWorline » Wed Jun 04, 2008 5:50 pm
Yeah it looks a little familar, with the exceptions that mine are made of 409 to resist cracking, filet TIG welded in the middle to be stronger and TIG welded inside and out at the flange to keep it all together there as well. Very nice job on the polish though! 8)
1st., 2nd 12valve, and 2nd - 3rd 24valve CoolerTubz
[img][img]http://i116.photobucket.com/albums/o28/DieselRam250/1st%20Gen%20CoolerTubz/c0c1359b.jpg[/img]
[/img]Image
[img][img]http://i116.photobucket.com/albums/o28/DieselRam250/Customers%20Trucks/S5009352.jpg[/img][/img]
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby flashgordon » Wed Jun 04, 2008 8:11 pm
I'm way happy with mine, That Tim made me:D
Flash
flashgordon
Postby roxxx » Wed Jun 04, 2008 9:45 pm
ha well i apologize thought you were only makin the tubz for the intercooler
and not for the intake
I would like all my pipes to have the rolled bead which i noticed they didnt have either and i dont have on the asa pipe either
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby JQmile » Thu Jun 05, 2008 10:25 am
Hey tim, do you (or could you) make an intake for a non i/c "stovepipe" model that starts off with a 3.5 inch dia instead of 3? I am thinking of doing a compressor upgrade to a HTT Stage IV and I think they use a 3.5 outlet.
thanks
Jason
JQmile
Postby TWorline » Thu Jun 05, 2008 8:05 pm
roxxx wrote:ha well i apologize thought you were only makin the tubz for the intercooler
roxxx:
Hey no apology needed! :) It is always good to see what is out there. Yeah I make them so we can have 3" from the turbo to the intake plate plus it elimanates 1 45 degree bend and about 10" of tubing compared to the stock unit not to mention the restriction at the air horn.
Jason:
Our member rbrettctd started to make some for the non I/C motors, not sure where he is at in his project, hopefully he will chime in. Somebody can correct me if I am wrong but, I think you can run any size outlet you want off of the Stage IV. Not exactly sure what you mean by "stovepipe" either?
Tim Worline
TWorline
Postby DTanklage » Fri Jun 06, 2008 12:31 pm
like tim said, "nice polish job"
that thing is for poser's
you need a bead on the end of it or it wont stay together
even at 30 psi
DTanklage
Postby roxxx » Sat Jun 07, 2008 8:00 am
Yep and i agree ;)
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
