PToombs wrote:CK, I'm going to be brutally honest. That looks like crap!
You need to step back and rethink that whole thing. Can you cut the tips off the studs? And grind the inside of the valve cover to get clearance?
Maybe make a spacer to fit under the cover, use a longer bolt so it sits a little higher and clears the stud?
I really think a "do over" is needed here.
Good luck!
PToombs wrote:Begle, pretty sure that's "Ultra Copper" RTV.
SNOOT wrote:I thought it was standard to have the rocker mid section milled down so the stud and nut went further down?
Begle1 wrote:SNOOT wrote:I thought it was standard to have the rocker mid section milled down so the stud and nut went further down?
It is, along with bottom tapping and clearanceing the valve covers.
