A1 head studs
A1 head studs
Postby cummins king » Sat Feb 07, 2009 4:44 pm
I got my motor back together and A1 head studs do not fit under our valve covers, you have to drill a hole in the valve covers to fit the studs
and it will end up looking like this
lol, oops not that one
this one
93 4X4 auto
cummins king
Postby Richie O » Sat Feb 07, 2009 4:46 pm
Im speechless :shock:
Postby Begle1 » Sat Feb 07, 2009 5:37 pm
That seriously struck you as the best solution? :lol:
Postby ccoxva » Sat Feb 07, 2009 6:01 pm
THE SHIRT SHOULD SAY HOLY SHIT THIS REALLY HAPPENS :hs: ????
1991 N/I 250
ccoxva
Postby PToombs » Sat Feb 07, 2009 6:30 pm
CK, I'm going to be brutally honest. That looks like crap! :shock:
You need to step back and rethink that whole thing. Can you cut the tips off the studs? And grind the inside of the valve cover to get clearance?
Maybe make a spacer to fit under the cover, use a longer bolt so it sits a little higher and clears the stud?
I really think a "do over" is needed here.
Good luck!
Postby Richie O » Sat Feb 07, 2009 6:44 pm
:oops: :oops: :oops: :oops:
Postby Begle1 » Sat Feb 07, 2009 6:52 pm
PToombs wrote:CK, I'm going to be brutally honest. That looks like crap! :shock:
Good luck!
If you can't cut the tops off the studs, you could at least JB Weld or tig little caps on the valve covers instead of... Using grease...
Postby TWorline » Sat Feb 07, 2009 7:22 pm
I was thinking about putting studs in as well, does anybody know if they make Blue silicone? Gotta keep everything color coordinated.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Sat Feb 07, 2009 7:40 pm
Begle, pretty sure that's "Ultra Copper" RTV. ;)
Postby fergavs » Sat Feb 07, 2009 7:53 pm
WOW. I don't even know what to............ WOW!!!! You.... drilled holes........Your just kidding right???? On my ARP studs I had to clearance the webbing on the underside of the cover slightly for stud clerance. If I couldn't have fit the studs I would have either bottom taped the holes (i should have anyway) or got different studs. I just can't believe you did that. Good luck!
fergavs
Postby Begle1 » Sat Feb 07, 2009 8:04 pm
PToombs wrote:Begle, pretty sure that's "Ultra Copper" RTV. ;)
Ah, well. that's slightly better...
Postby SNOOT » Sat Feb 07, 2009 8:19 pm
I thought it was standard to have the rocker mid section milled down so the stud and nut went further down?
1993 W350
SNOOT
Postby Begle1 » Sat Feb 07, 2009 8:21 pm
SNOOT wrote:I thought it was standard to have the rocker mid section milled down so the stud and nut went further down?
It is, along with bottom tapping and clearanceing the valve covers.
Postby PToombs » Sat Feb 07, 2009 8:39 pm
Well, it is for most people! ;)
Postby burnt_servo » Sun Feb 08, 2009 5:03 am
what about somehow getting the studs to sink deeper into the block ?
'93 w250 .... stock ...
burnt_servo
