Went to the track last night
Postby gear jammer 91" » Sun May 10, 2009 8:59 am
I got some new 1/4 mile numbers last night. I wasn't running any methanol in the water/meth tank just water, and I was leaving soft in 2wd to keep from spinning. I beat a late 60's Buick, a 24 valve, and a common rail 8) . I also got my but handed to me on one pass, but I knew it was coming. I staged up next to source auto's 05 drag truck :lol: , Rip was behing the wheel and put down a 11.9.
R/T - .327 :oops:
60' - 2.52
1/8 - 9.98
MPH - 75.40
1/4 - 15.18
MPH - 92.6
Source Auto's Common Rail
R/T - .063
60 - 1.73
1/8 - 7.67
MPH - 90.61
1/4 - 11.95
MPH - 114.57
01 LB7
gear jammer 91"
Postby BC847 » Sun May 10, 2009 10:34 am
Nice run. Especially with rowing the gears. 8)
Try launching in 4WD to eliminate the tire spinning. 10psig boost at the line is a good number to start with.
Postby Richie O » Sun May 10, 2009 11:13 am
BC847 wrote:Nice run. Especially with rowing the gears. 8)
Im to affraid of busting stuff to do that. :shock:
Postby Richie O » Sun May 10, 2009 11:14 am
And by the way you were a full second faster in the 1/8th with your getrag than I was with mine. :oops: :oops:
Postby soggy » Sun May 10, 2009 1:02 pm
Nice gearjammer, yeah id def say you would be around 14.6 or .7 if you left in 4wd at 10 lbs or so. I know when i ran 15.4 @ 86 my 60 ft was right around 2 flat, so you could pick up another .5 there easily. It's nice to have some decently fast 1st gens around. 8)
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby 93_Fummins » Sun May 10, 2009 2:37 pm
soggy wrote:Nice gearjammer, yeah id def say you would be around 14.6 or .7 if you left in 4wd at 10 lbs or so...
That, and if you had another cup of coffee and didn't fall asleep at the tree.
D'oh! :shock:
93_Fummins
Postby soggy » Sun May 10, 2009 4:14 pm
RT has nothing to do with your ET, I caught a mustang sleeping at the tree and beat him to the finish line but he still had a better time than me
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby 93_Fummins » Sun May 10, 2009 5:51 pm
soggy wrote:RT has nothing to do with your ET, I caught a mustang sleeping at the tree and beat him to the finish line but he still had a better time than me
Oh, snap! You got me... :oops:
93_Fummins
Postby BC847 » Sun May 10, 2009 6:09 pm
Yup (I'm 42). ...
Postby gear jammer 91" » Sun May 10, 2009 9:34 pm
I was so concerned with not frying the tires off that It hurt my R/T, at least that's my excuse. :lol: I'm too afraid of busting stuff to launch hard in 4wd also. My tranny has a little slop in it as it is. Those were the numbers from my best pass, my worst R/T was .419, 1/8th time was 10.53, and my worst 1/4 was 15.64. This was only my second time at the track so I'm still learning, I have figured out that my truck is faster when I shift around 3500RPM than it is when I shift around 3000RPM, and I roll through the traps at about 1400 degrees with about 35# of boost and the speedo is showing closer to 100MPH.
By the way, I don't think the brakes on our trucks were meant to stop these heavy beasts from 100MPH quickly.
01 LB7
gear jammer 91"
Return to Competition
