Super Hx40 vs 62mm S300
Postby KTA » Wed Jun 03, 2009 7:27 am
I know a lot is said about the two and the HX40 usually gets a bad rap. For years I have sung the praises of The Super Hx40 for properly fueled trucks, and it looks like looking at the maps that I was right.
Postby Philip » Wed Jun 03, 2009 8:18 am
I don't know where you found that map chart.
Thank you.
I have been wanting and looking for one for the Super 40.
Postby RSWORDS » Wed Jun 03, 2009 9:19 am
I think the super HX40 is a great turbo that flows well, But its the weak shaft that did it in for me, I bark my Silver 62 ALOT. Weather or not I would have broke a HX40 I dont know, never had one, come to think of it never seen one broke either so who knows!
Thanks for the charts Brian!
RSWORDS
Postby KTA » Wed Jun 03, 2009 2:36 pm
Oops I forgot to mention since Holset is in Europe those units are in metric so in actuality the peak mass flow for the Super Hx40 at 70% efficiency is 66lbs/m.
Postby fergavs » Wed Jun 03, 2009 5:40 pm
HAHA ya its a good thing you mentioned that Brian. I looked t the super 40 map and :shock: I'm thinking this thing can flow 80lbs/min thats crazy. 66lbs sounds about right. Thats pretty good. Now keep in mind the map that is shown for the 62mm is probably the std 62mm not the borg warner with the extended tip compressor wheel. That increases top end flow a fair bit.
fergavs
Postby Ramrod90 » Wed Jun 10, 2009 9:58 pm
I m not really good at reading these so could someone please tell me what the max psi (of cool usable boost) these two turbo's can produce. danke.
Ramrod90
Postby KTA » Thu Jun 11, 2009 6:05 am
The S300 will be about 42psi, the Super Hx40 would be about 52psi, and the regular hx40 about 45psi.
Postby RSWORDS » Thu Jun 11, 2009 7:24 am
KTA wrote:The S300 will be about 42psi, the Super Hx40 would be about 52psi, and the regular hx40 about 45psi.
Now this is for a "stock" S300. I wonder how an "aftermarket" S300 would fair. like a Super Phat shaft 62 or similar....
RSWORDS
Postby apwatson50 » Thu Jun 11, 2009 9:42 am
Can you upgrade a regular 40 to a super 40? Or is there more than just a compressor wheel/housing change?
92 Cummins, 4x4, 270K miles
apwatson50
Postby KTA » Sat Jun 13, 2009 8:32 am
Both the comp and turbine wheels are diffrent so no it can't be practicly done.
Postby Ramrod90 » Mon Jul 06, 2009 11:36 pm
Where can I buy a super 40? I have been looking around but have had no luck. Thanks.
Ramrod90
Postby KTA » Tue Jul 07, 2009 8:46 am
I can get you one if you want it. When I checked about a month ago my supplier had 2 in stock.
Postby bgilbert » Tue Jul 07, 2009 12:41 pm
KTA wrote:Both the comp and turbine wheels are diffrent so no it can't be practicly done.
Can a cartridge be bought? Cheaper than a s300 62/71 cartridge? Not that I need a 40 or even have any 40 housings.
Bill Gilbert
Postby gear jammer 91" » Tue Jul 07, 2009 9:22 pm
I know it's been asked asked before but, how do you tell the difference between a 40 and a super 40?
01 LB7
gear jammer 91"
Users browsing this forum: No registered users and 88 guests
