4x4 conversion
4x4 conversion
Postby Cannon » Sat May 02, 2009 7:18 pm
ImageDoing a 2wd to 4wd any hints would be helpful
Cannon
Postby Philip » Sat May 02, 2009 9:02 pm
Your going to be good friends with a grinder and cutoff wheel. An air chisel with a 7/16" punch to drive the cut off revits will help.
A body swap would be the fastest way.
Postby jimmyt83 » Tue Jun 16, 2009 8:59 am
Search around for Solid Axle Swap threads...the process will be about the same, except occasionally you can luck out and use all stock parts from a 4WD truck, and once in a blue moon, they will bolt right up. I don't know a whole lot about the Dodge stuff, but if you know someone with a 4x4 Ram you can compare the 2...
'94 Chevy K1500, '93 IC CUMMINS Conversion, A518 (upgrades to come), 1-ton SAS, 3.73 gears, 39.5" Boggers on 15x14 Pro Comp wheels
jimmyt83
