KTA wrote:The chevrolet adjustable drag link cured this problem for m
e!
Does it have the stock pitman and draglink? You can't lift them at all and expect it to steer right without a drop pitman or crossover steering. Even an adjustable draglink is just a band-aid because it's still working at the wrong angle. You probably need one of these:The chevrolet adjustable drag link cured this problem for m
Where did you get that pitman arm? How much lift do you have? My truck has a two-three inch I believe and the only pitman arm I have came across was for a 6inch lift....
e!
What chevy does that link come from, and is a simple bolt on?
I believe he KTA is talking about on off of like a 87 v20 chevy 4x4. My brother has one he is putting together and I held his adjustable drag link up to mine and it looks like it would work great if you put the front end of the drag link up and the back end down IMO
