Front Axle Ladder Bars?
Postby Cummins Junkie » Mon Nov 23, 2009 12:09 pm
Has any one thought of this, since we have leaf springs in the front also? Just a thought, what do you guys think?
1991.5 W250 NV4500 Swap, Ats Manifold, Dual 5" Stacks, Autometer Gauges,P-Pump Swap, KDP Beat Into Submission, 4k GSK, 0 Plate, 191 DVs, P/S Intercooler, 3" Stainless Cooler Tubez, BHAF, Super Hx40, 370s
Cummins Junkie
Postby Raymo » Tue Nov 24, 2009 8:15 am
I did this on my mud truck years ago, only benefit with the 38.5's that I seen was the front didn't bounce as hard when climbing a steep hill full throttle. All I used were hiem joints and straight DOM tube, only two mounting points per side, not the three with a "ladder bar".
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby Cummins Junkie » Tue Nov 24, 2009 9:54 am
Would you be able to maybe e-mail some pics of how you did yours?
Cummins Junkie
Postby Raymo » Tue Nov 24, 2009 10:12 am
Well that old truck has become ten other trucks since I retired it lol. It was just two bottom links attached at the bottom of the tube, close to the knuckles and attached to the frame even with the back of the transfercase. Straight forward two link set-up pretty much. Two pieces of 1.5" DOM, 4 7/8" hiem joints and link tabs on frame and axle.
I get my hiem joints, bushings ect. from this guy. www.ruffstuffspecialties.com
Raymo
Postby 95ram » Tue Dec 01, 2009 7:19 pm
Raymo wrote:Well that old truck has become ten other trucks since I retired it lol. It was just two bottom links attached at the bottom of the tube, close to the knuckles and attached to the frame even with the back of the transfercase. Straight forward two link set-up pretty much. Two pieces of 1.5" DOM, 4 7/8" hiem joints and link tabs on frame and axle.
That's not a bad site.
95ram
Postby CaptainChrysler » Wed Dec 02, 2009 11:12 am
We build them for the '89. They seem to help.
1993 W-350 EXT CAB SRW
GETRAG, DC-1'S, 285'S
370'S, HX40, 5" EXHAUST, BHAF
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
WATER-2-AIR IC, SBC DD
CaptainChrysler
Postby Raymo » Wed Dec 02, 2009 2:57 pm
If you watch the site, he usually has sales on a bunch of stuff just to keep things moving.
Raymo
Postby Cummins Junkie » Thu Dec 03, 2009 9:43 am
Sweet man thanks for the pics, thats sort of what I had in mind!
CaptainChrysler wrote:We build them for the '89. They seem to help.
Cummins Junkie
Postby 92OLBLue » Thu Dec 31, 2009 8:20 am
Those look really nice. to bad you wouldn't sell a kit like that..
1992 W250 Reg Cab 4x4
P-pumped
Nv4500 conversion
Southbend 3850 Dual Disk
405rwhp
92OLBLue
Postby KTA » Thu Dec 31, 2009 12:24 pm
I think for street use though you would need your links coming off the front. In the setup pictured the links are fighting the articulation of the axle. The bars are fixed on the same end as the shackle which is free, so now both ends act like they are fixed so it has to ride terribly rough. If both ends were fixed in the front and parallel the axle would be free to move up and down still via the spring movement and the flex allowed by the shackles.
Return to Competition
