23 spline to 29 spline Adapter, Any Interest?
Re: 23 spline to 29 spline Adapter, Any Interest?
Postby rockjeep73 » Tue Mar 09, 2010 2:03 pm
BobS wrote:Do those have the provision for the internal snap ring to keep it from walking fore and aft on the splines or a way that it always remains in the correct position?
I added a piece in the middle so there will be no issues with it walking forward or back.
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby bgilbert » Tue Mar 09, 2010 3:23 pm
I see some broken transfer case input shafts in the future from the guys putting a getrag in front of the unbelievably tiny input shaft of the auto (23 spline) transfer case. This coupler looks really good and I don't ever see it being the failure. I should get a picture, or maybe someone else will before I do, of the tiny 23 spline input shaft versus the larger 29 spline input shaft. It's not the splines, it's the diameter of the shaft.
Bill Gilbert
Postby 1STGENFARMBOY » Tue Mar 09, 2010 3:33 pm
Bill can you just buy a 29 shaft and change it into the auto transfercase, cause i'm wanting
to put a getrag in my truck someday and i need to know if i need a T/C also.
Thanks Dar
Postby bgilbert » Fri Mar 12, 2010 10:47 am
1STGENFARMBOY wrote:Bill can you just buy a 29 shaft and change it into the auto transfercase, cause i'm wanting
Thanks Dar
Yes, nothing a good machinist can't do. You might not be able to run an input seal in the 205 though. Philip and I are working on that though.
Postby therabbittree » Tue Apr 13, 2010 4:05 pm
this may allow guys to run a doubler 203/205 kit now as any one with a 29 spline trans output was out of luck as no 203's ever fit a 29 spline trans output... i had asked soem places to make what you made and they didn't want to build it for me.
I probbaly will be picking one up when i get some extra cash.
therabbittree
Postby rockjeep73 » Wed Apr 14, 2010 1:43 am
therabbittree wrote:this may allow guys to run a doubler 203/205 kit now as any one with a 29 spline trans output was out of luck as no 203's ever fit a 29 spline trans output... i had asked soem places to make what you made and they didn't want to build it for me.
Sounds good and thanks for the info, I am finding out there are many different uses for the coupler other than my original intentions.
Question: Are there 203's with a male input shaft? The only ones I have seen had a female input and didnt use a coupler.
rockjeep73
Postby therabbittree » Wed Apr 14, 2010 4:46 am
HA my Bad, You are correct the connector is a spud shaft any way you could make up a spud shaft that is 29 spline female and 23 spline male?...
Thanks,
Deo
therabbittree
Postby Stoner93 » Thu Mar 28, 2013 9:49 am
I'm doing a auto to nv4500 conversion and need the coupler how do I go about getting one?
Stoner93
Postby CumminsPower59 » Thu Mar 28, 2013 10:42 am
Stoner93 wrote:I'm doing a auto to nv4500 conversion and need the coupler how do I go about getting one?
Try this link ;)
http://shop.shsdiesel.com/23-spline-to- ... OUPLER.htm
Postby bmoeller » Sat Mar 30, 2013 7:18 pm
Back ordered. Yea....................
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby CumminsPower59 » Sat Mar 30, 2013 7:29 pm
Whoops...didn't see that part.
Postby bmoeller » Sat Mar 30, 2013 8:56 pm
I need one. :P
bmoeller
Postby rockjeep73 » Mon Apr 01, 2013 7:06 pm
If you have a 23 spline core to send in I can have them built and shipped out about 3 days after receiving your core.
rockjeep73
Postby Mark Nixon » Mon Apr 01, 2013 8:47 pm
rockjeep73 wrote:If you have a 23 spline core to send in I can have them built and shipped out about 3 days after receiving your core.
I saw this coming. :roll:
The aftermarket saw the need for the 29 spline couplers, but now there's a shortage of 23s. :?
I just picked up a 23 spline t-case to-day and wouldn't you know that the coupler for it is bad on BOTH sides. :/
