PToombs wrote:Bill, what exactly comes in the kit? I paid about $30 for the whole thing to replace everything from 1 shaft to the other.
I knew I shoulda taken a picture of it. You get: 1 'crimp on cover' (supposed to hold the rubber seal onto the coupler). 1 seal, 1 'cross pin' (presses into the steering shaft), 1 roll pin (holds coupler to steering box nub), then inside the coupler is 1 metal clip, and 2 hard square looking metal pieces lol. Finally a very small roll pin, so to speak, that you tap into the side of the coupler. Keeps the coupler from coming off the steering shaft. Basically, a rebuild kit Pete!
See what I mean about I should've taken a pic lol.
With the help of a press or vise, heat from a torch, roll pin punches, and a couple large pry bars it's an easy job. The hardest part I felt was getting the coupler off the steering box and then trying to 'crimp' the silly seal retainer on the coupler. That last part I didn't really get accomplished. Looks like I'll be looking for a good boot.
