2001 Dana 70 with discs swap q's
Postby bigred cummins » Mon Jun 21, 2010 2:00 pm
Just picked up a 2001 D70 with disc brakes and a mag-hytec cover for $400. Is there anything I should know before doing the swap? will the stock proportioning valve and ABS be fine or do I need an after market prop-valve? Are the widths similar? And also is there any parts change-over with the axle I have now?
bigred cummins
Re: 2001 Dana 70 with discs swap q's
Postby bigred cummins » Mon Jul 19, 2010 5:30 pm
just so you guys know, the widths are different by a ton, the spring perches are wider, and the brake line is shorter.
bigred cummins
Postby SNOOT » Mon Jul 19, 2010 6:16 pm
You may also have issues with the shock mounts. Some were one front and one rear mount and others were both rear mount.
1993 W350
SNOOT
Postby bigred cummins » Mon Jul 19, 2010 11:32 pm
Yup. Forgot to add that. You need to cut off the ones on the 2nd gen axle if you want to re-use the first gen shock mounts. Its about 5 inches wider than the 1st gen axle.
bigred cummins
Postby dpuckett » Thu Jul 29, 2010 1:02 pm
I did a D80 swap into my D350, and everything but the driveshaft and shocks was a direct fit. But, it WAS a p/u dually, not a SRW- maybe that was the difference.
