ahale2772 wrote:well keep in mind that the injector lines need to be custom and u no longer have the option of having a mechanical lift pump on the side of the block......i think what were all getting to is that u should just build up the ve motor ....its way cooler
burnt_servo wrote:a while back i read a thread where a gu put a ve pump into a 24 valve , it was a almost direct bolt on , and really only needed adapters to hook the ve up to the vp44 injection lines ...... ( besides lowering the pop presure of the injectors ) .
Users browsing this forum: No registered users and 84 guests
