Ace wrote:Wow, I've never seen rear blocks that high before. I couldn't see any traction bars either. It must pull enough axle wrap to buck like a wild bull starting out hard in 2wd on dry pavement.
redneckroot wrote:Do you have any pics of your rear drive shaft hoops? It looks like something interesting going on there.
PToombs wrote:You should straighten your axle vent hose. The loop is not a good thing. If it gets moisture or oil in it, it won't actually vent. It will act like a thermometer with the fluid going back and forth, and no air getting thru.
