My New 2002 24V Cummins 4x4
All of 'em
Re: My New 2002 24V Cummins 4x4
Postby Bad93Cummins » Tue Sep 28, 2010 5:55 pm
Ya its the 0216 code, so the pump is on its way out, found a pump new from jkidd on dieselbombers for pretty good price.
I traded the dually for this as i got rid of my toys and not hualing as much so no need for dually, plus it need about $1500 worth of work and back doors didn't open so kinda pain.
Got a/c fixed today!!!
Bad93Cummins
Postby Bad93Cummins » Mon Oct 04, 2010 4:21 pm
10-4-10 Got the new/used tires on!! Now saving up for new VP44 injection pump, Napa filter, Quadzilla Adrenaline with Pulse Monitor and 35x12.50x20 Nitto Trail Grappler MT's!
10-2-10 At taco bell with old balld tires
10-4-10 At new tires put on
Bad93Cummins
Postby PToombs » Mon Oct 04, 2010 4:25 pm
Better plan on a lift pump too, unless it's been changed recently.
Postby Bad93Cummins » Mon Oct 04, 2010 4:38 pm
Its got a holley blue pump right now, but looking to get the holley black(for the price) or might just get the air dog 150 or 165 just really tight on money esspecilly sence I got to buy new injection pump and gota spend $100 to fix front d-shaft, and being outa work right now aint' helping!!
Bad93Cummins
Postby PToombs » Mon Oct 04, 2010 4:52 pm
The blue is ok short term, my buddy runs one, or was. Not positive what he has now. Buy a fuel pressure guage so you can watch it and run the blue until you can get an AD.
Postby Bad93Cummins » Mon Oct 04, 2010 4:55 pm
Ya im going to try and get a fuel psi gauge same time I replace the injection pump, then shortly after ill get the holly black or maybe(deppending on income) ill get the AD.
Bad93Cummins
Postby ahale2772 » Wed Oct 06, 2010 11:45 am
that new vp will die very soon as well if u dont give it good COOL fuel right away, one bad heatcycle on the pump can crak the chip on the top of the pump and give u a 1693 code again, the holley blue is not enough, pull the front drive shaft get a nice lift pump
Postby Bad93Cummins » Wed Oct 06, 2010 7:02 pm
Yes I paln on getting either a holley black or raptor depending how $ at the time
Bad93Cummins
Postby Bad93Cummins » Wed Oct 06, 2010 8:43 pm
10-6-10
Lifted Dirtymax, My 24V Cummins
Probley trading that toyota in the pic's for a 89 reg cab 2wd first gen with new injection pump 727 auto and single stack, runs and drives but leaks freeon and injectors leak a bit
Bad93Cummins
Return to Other diesels
