1994 F350 cc drw conversion.
Re: 1994 F350 cc drw conversion.
Postby thumpertrev » Sat Feb 26, 2011 9:36 pm
Kinda cool 8)
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby thumpertrev » Sun Feb 27, 2011 10:03 pm
Wow! You guys must be sleeping....no flamer comment on the pic. Anyways, need advice. Like I said I got it runnin but this thing smokes REALLY bad. White smoke. Not coolant (no rad in truck yet). Adjusted all valves int- .010, exh- .020. No charger hooked up yet.Does this at all rpms. More with more revs. I did take the injectors apart for cleaning but thought I was real careful to keep each part with the right injector but, now I think I must have screwed that up. Sound about right? If you think its the injector(s) Im ready to buy a set. Would the sdx 2 be a clean injector thats still not so small that it wont work with my twins? Not looking for mega power here...this is more of a towing setup.
thumpertrev
Postby thumpertrev » Mon Feb 28, 2011 6:15 pm
Checked the temp Near manifold gasket today and found #2 and #6 to be much colder than the rest. Ordered SDX II today. Hope I'm right. Feedback.......please!! :scratch:
thumpertrev
Postby PToombs » Mon Feb 28, 2011 6:21 pm
I figured I'd let the flamer comment slip by this time, I'm not always an a-hole. :mrgreen: (i'll get crap about that!)
When you say "no charger", you mean no turbo? It will smoke like that, not enough air, and worse with higher rpms! The temp check on the manifold says there is a problem there too.
Postby Richie O » Mon Feb 28, 2011 6:54 pm
I have never had an injector apart, but for sure you need to put the same shims back in, and I would say they should be checked if you want to run them. I think your SDX choice may help out. You may have a couple injectors thats frigged.
Postby thumpertrev » Mon Feb 28, 2011 7:08 pm
No charger. Have not built the tubes yet, but wouldn't it run black not white?
thumpertrev
Postby ahale2772 » Tue Mar 01, 2011 3:51 am
nope no turbo will make it run white not black
Postby thumpertrev » Tue Mar 01, 2011 5:50 pm
I humbly need a little schooling here. The only other diesel I have owned was a 6.5 I put into a built solid axle S-10. Before I found the Banks sidewinder kit (in a salvage yard for only $100 :shock: ) the 6.5 smoked black much worse than after the turbo. This is where my black/white smoke confusion comes from. I thought white was unignited and black was not completely combusted. :?: :scratch: Please educate me.
thumpertrev
Postby PToombs » Tue Mar 01, 2011 6:09 pm
If the engine is cold it will be more white than black. The injector issue will make it even more white. Otherwise you are correct, if you blow a turbo boot or something like that where you are loading the engine it would be black.
Postby thumpertrev » Tue Mar 01, 2011 9:18 pm
Now I got it. Thanks. Injectors should be in next week. I hope that at least makes it run well enough to drive in and out the shop. If it still smokes some I wont worry about it 'til its all together and I can get some heat in the motor. I'm trying to make this wife friendly...What do you think about using a glow plug controller to heat the grid heater?
thumpertrev
Postby ellis93 » Wed Mar 02, 2011 6:23 am
By controller I'd guess you'd be asking about the IDI style? If you are, IMHO, don't waste the money. The aftermarket ones are short lived.
I think you could take the relays and turn them on with a push button.
Postby ahale2772 » Wed Mar 02, 2011 9:25 am
push button is in fact the easiest, I recomend keeping the relays in but runnin your own signal wire, the IDI style relays are pretty much junk, you wont have a problem making it wife friendly, its just once they learn to like it and then they start putting their air freshners and yelling at you for making your own truck dirty...thats when it becomes a problem :D
Postby thumpertrev » Wed Mar 02, 2011 9:43 am
:grrr: :thatsucks:
thumpertrev
Postby ahale2772 » Wed Mar 02, 2011 10:09 am
I think its payaback for not fixing her truck, shes got a 94 F250 with a 351, 438,000 miles original engine and transmission, its been sitting scince we got her a nice 34mpg mitsubishi, she keeps asking me to make it road worthy again and i keep saying no chance, way to much of a PITA to sink money into a truck that has 438k on a 351 ....its a lawn ornamaent now :D
Postby thumpertrev » Sat Mar 12, 2011 9:57 pm
Worked on it friday and got a few more little things done.
Built my 5" downpipe.
Got the heater grids wired and working.
Repaired pass. floorboard where I clearanced for downpipe.
Got regulator wired up an charging.
Put on my hvac housing.
Finished the transfercase shifter boot.
And mounted my fan controller.
Anxiously waitin on injectors. :bounce:
All that and still so much left to do.... :roll:
thumpertrev
Users browsing this forum: No registered users and 107 guests
