best D80 dually axle?
Re: best D80 dually axle?
Postby Mark Nixon » Thu Jul 14, 2011 4:11 pm
I just acquired a '97 3.54 Dually drum brake D-80 last night. :?
Not sure what I'm doing with it, though. :roll:
If I were keeping the DAMNCHARGER.....but that's just insane thinking there. ;)
Postby Awesome Bill » Thu Jul 14, 2011 6:45 pm
ahale2772 wrote:thanks for the replies guys, I would go 14 bolt if i could find one with 3.54 gears, im sure I could buy those grears aftermarket but i dont really want to get into ripping the carrier out..but then again with the ability to buy a 14bolt for so cheep maybe I should...
Look around a little. Most people give away gears that low. Heck if I had another set of 3.54's I'd give them to you. As for setting up the gears, it's just about the easiest axle to set up IMHO. Do you know the wms your looking for? I only ask because a true dually width axle is kinda hard to find. At least it was for me anyway.
91.5 w250 DD toe rig
92 fj80 6bt, 1tons
70 fj40 v8, staK 3speed, 42's
Awesome Bill
Postby ahale2772 » Fri Jul 15, 2011 5:29 am
Mark any idea what the brake setup is on that axle? Drum/ shoe/ wheelcyl size?
Postby Fred_M1010 » Fri Jul 15, 2011 4:36 pm
dazedandconfused wrote:I'm personally not a fan of the 14 bolt. We have killed 8 of them like they were nothing. 2 in a stock big block 97 GMC, 1 in a 95 Chevy 3500, 3 in my 81 crew can chevy with an 89 Cummins 727 combo & 2 in a 94 Chevy 3500 6.5. They do not like the abuse we have put then threw.
Huh, I thought they where at least as strong as the dana 70.
What part of it do you usually break?
Is it the ring and pinion or the axle shafts or something else?
-91.5 W250
Fred_M1010
Postby Mark Nixon » Fri Jul 15, 2011 4:45 pm
IIRC there are 2 distinct versions of the Corporate 14 bolt, both have different ring gear diameters.
One is under some older Medium Duty trucks, as well as certain '70s and '80s 1 tons and has (IIRC) an 11.5" ring gear.
The other, purportedly more common, version is significantly smaller in ring gear diameter.
The one I had was definitely not the wimp of the pair, so I was told.
Postby dazedandconfused » Fri Jul 15, 2011 7:22 pm
Always ate the pinion and ring gear. Pinion support bearing would fail and munch the pinion gear and ring gear.
Postby Fred_M1010 » Sat Jul 16, 2011 1:34 am
Mark Nixon wrote:IIRC there are 2 distinct versions of the Corporate 14 bolt, both have different ring gear diameters.
There's actually three, a 9.5" semi floater, a 10.5" full floater, and a 11.5" full floater (2001 and newer only).
But considering the trucks he mentioned, I reckoned he meant the 10.5" FF.
Both the later are considered pretty bullit proof in the Chevy community,
but I guess they don't use cummins engines as often on the other hand ;)
Wouldn't that be more due to poor maintenance?
I can't see how the support bearing would fail due to too much load.
-91.5 W250
Fred_M1010
Postby dazedandconfused » Sat Jul 16, 2011 6:35 am
if you shock load them at all they break the pinion support bearings. They don't like heavy trucks and really being worked. Every year plowing snow we break them. I usually get 30,000 miles out of them before they are junk. The dana 70 is stronger. I have a buddy that pulls a chevy BB 4x4 and he couldn't make a 10.5 ff 14 bolt with all the goodies last a pass or 2 on the track. In a light rig they are good but our trucks are over 11,000 pounds we are eating them in.
Postby Mark Nixon » Sat Jul 16, 2011 7:09 am
Eating up the pinion bearings is one thing, you may have already seen what sled pullers do to Dana 70s.
Pulltilbroke probably has photo evidence of his 70's demise around somewhere.
I've no doubt that the 14 bolt has had issues, in that it, like most axles of it's design, is technically "light duty" to "light medium duty" in weight rating.
Postby dazedandconfused » Sat Jul 16, 2011 7:27 am
I've killed some Dana 70s as well. You can't find either rear around here though in junkyards or anywhere else. If you do find a FF 14bolt they want stupid money for them. I'd personally run a 80 or an AAM 11.5. I'm hoping I can keep my 70 alive in the duck. I tend to be hard on parts anyway.
Postby Fred_M1010 » Sun Jul 17, 2011 8:20 am
Ok, I understand.
I'm more of an off-road guy, so the rigs I'm used to are never that heavy,
and rarely sees long time abuse like plow trucks.
-91.5 W250
Fred_M1010
Postby CAJUN 93 » Mon Jul 18, 2011 7:09 am
back in my gm parts days (mid to late 90's) we used to rebuild 14 bolts regularly. bellsouth service trucks would eat them like candy. the rear pinion support bearing woudl fail and usually lead to ring and pinion failure and occasional carrier failure. the housing itself held up well and hardly ever failed. made good money back then on them. i didn't see anything impressive enough to make want to have one.
daryl
CAJUN 93
Postby collegekid » Mon Jul 18, 2011 9:07 am
Dumb Question: how can you tell if your axle is full float or semi float
collegekid
Postby dazedandconfused » Mon Jul 18, 2011 9:10 am
FF the axle bolts on the outside to the drum. Semi floater with have a c clip usually holding them in depending on the axle.
Postby collegekid » Mon Jul 18, 2011 9:12 am
So were most of our trucks bought with FF
collegekid
