Show me your mounts!
Postby Broncman » Fri Jul 29, 2011 6:19 pm
Post up a pic of your motor mounts, transmission mounts, etc for your swaps! I will keep them here in this thread. That way we can have a thread for one of the most searched after items when people are doing their swaps.
Coming soon...78 F350 2wd mounts....as soon as I get them done ;)
Broncman
Re: Show me your mounts!
Postby thumpertrev » Mon Aug 08, 2011 8:48 pm
1994 f350/1992 12v Passenger mount
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby Higbean » Fri Mar 23, 2012 9:31 pm
78 ford crew
Higbean
Postby T_wilson_3 » Tue Mar 27, 2012 8:20 pm
Anyone have any 73-87 Chevy mounts?
Tory
:grin: head
86 Chevy 4wd cummins swap in the making
91 D350 dd/donor stock
T_wilson_3
Postby cmann250 » Wed Mar 28, 2012 4:56 am
Avalanche Engineering sells them
Postby T_wilson_3 » Wed Mar 28, 2012 7:27 am
Avalanche is out of business now. I called another place that has them but I can't see spending $600+ when I have the the material and capability to make them.
I have searched for the dimensions but have no luck. I was hoping to have it made before I pull the motor out of my donor truck.
Tory
:grin: head
T_wilson_3
Postby T_wilson_3 » Tue Apr 17, 2012 5:49 am
1986 Chevy 4wd
I couldnt spend $600+ buying a mount and after a few days of staring at the truck thinking how I was going to make one this was what I came up with. I hope I never plan on replacing that cummins with something else! :lol:
I started building the mounts around the motor.
Fits like a glove! :D
I have a 6" lift so clearance underneath wasnt a problem.
Tory
:grin: head
T_wilson_3
Postby Kasper Cummins » Tue Apr 17, 2012 6:01 pm
Higbean wrote:78 ford crew
That's really good TIG welding :grin:
92 W250 club cab
Kasper Cummins
Postby bighroder » Thu Aug 30, 2012 5:18 pm
T_wilson_3 wrote:1986 Chevy 4wd
Your dana44 is hating life right now haha
86 suburban/pickup conversion project "Dont Even Matter"
Dana 60, 14bff, 12v ve, nv4500, np205
http://1stgen.org/viewtopic.php?f=32&t=13252
bighroder
Postby BobS » Fri Aug 31, 2012 5:00 am
T_wilson_3 wrote:Anyone have any 73-87 Chevy mounts?
Try Scott from Tennessee Diesel Conversions who makes & advertises them over on 4BTswaps.com in the "vendor section" - His member name over there is crewcab59.
I'll toss in a few tips that I learned during the 2WD to 4WD Dodge crewcab & from other conversions I have looked at. You engine tilt from from to rear needs to be within +/- 1-1/2 degrees of your rear axle pinion angle. This keeps your drive shafts close to the factory specs. Also, when doing a 4WD you can tilt the engine off vertical to gain clearances for the frame, exhaust pipe, crossmember & for the front drive shaft & transfer case.
If you need to notch a frame or crossmember it is usually a good idea to grind the notch and weld a piece of 1/16" - 1/8" at a right angle to the cut. This forms a single right angle to the cut and reinforces the notch and gives the cut area some of the strength that it has lost.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Users browsing this forum: No registered users and 70 guests
