Dana 60s
Dana 60s
Postby 89workhorse » Sat Dec 17, 2011 3:41 pm
I have a 4wd 1989 250 automatic, was wondering what gear ratios might this have in it, gettin ready to do a nv4500 dont want it to be high geared
1989 D250 4wd, Maxed ve, denny t stage 2, 366 spring, 60mm turbo upgrade, 4" straight pipe, ddp stage 3 injectors, glow shift guages, 180xxx miles
2001 2500HD 2wd, all stock (not for long) lb7 6.6 duramax, 230xxx miles
89workhorse
Re: Dana 60s
Postby bgilbert » Sat Dec 17, 2011 3:46 pm
3.07/3.08.
Bill Gilbert
Re: Dana 60s
Postby 89workhorse » Sat Dec 17, 2011 4:26 pm
I dont see any markings on the housings, any other way to check, w/o pulling dif cover
89workhorse
Re: Dana 60s
Postby Tacoclaw » Sat Dec 17, 2011 5:15 pm
How fast does your truck go? 3.08s were the only option available in the old non-OD trucks AFAIK, but If your truck can go faster than 70MPH, it's pretty well has to have 3.08s. :lol:
Re: Dana 60s
Postby 89workhorse » Sat Dec 17, 2011 5:53 pm
When I first got it stock wouldnt break 70, now barely 85mph max, after 60 takes along time to hit it, so does that mean probably 3.08s
89workhorse
Re: Dana 60s
Postby Philip » Sat Dec 17, 2011 6:44 pm
You have 3:08's. You wouldn't get above about 60 with 3:54's.
Re: Dana 60s
Postby 89workhorse » Sat Dec 17, 2011 6:47 pm
Alright, that sucks looks like im changin them to, thanks yall
89workhorse
Re: Dana 60s
Postby oldestof11 » Sat Dec 17, 2011 6:58 pm
You have a dana 60 front and dana 70 rear, just so you know.
Re: Dana 60s
Postby Tacoclaw » Sat Dec 17, 2011 7:33 pm
oldestof11 wrote:You have a dana 61 front and dana 71 rear, just so you know.
Also, why are you changing them, do you tow heavy with it? I run 3.08s with a getrag and 32" tires. There's a funny spot right around 45-50 where I can't quite go into 5th yet, but otherwise it's nice to drive. The tall gears are good for getting the turbo spooled down low and you get to drive it like an actual 5 speed.
Re: Dana 60s
Postby PapeCAT » Fri Jan 06, 2012 10:47 am
You have the "SPECIAL" Dana 61/71 combo that will take ring gear spacers to set up with 3:54-4:10 gears. The housings are cast differently to make room for the big pinion needed for the 3.07 gearset. MANY out there would trade you their 3.54/4:10 axles straight across for yours. I ran 3.07s with the getrag in two of my trucks in the past. It is a great setup to allow you to tow in 4th... (easy on the trans)
PapeCAT
Users browsing this forum: No registered users and 296 guests
