braking system,hydroboost setup
Postby kenmartin » Sat Dec 24, 2011 6:13 am
anyone run a hydoboost braking system off a stock steering pump 1990 6bt please post pics of your line routing thanks
1990 , 80 over sticks, new head with 80 pound springs, and 4" downpipe, waiting for pullitbroke to help it be what it can be!
kenmartin
Re: braking system,hydroboost setup
Postby Gots_a_sol » Sat Dec 24, 2011 8:44 am
Stock chevy booster/master cylinder and matching lines, just hand bent a little bit.
I had t'd the return lines for the booster and steering box together at first
But my stock pump was starting to leak, so I have since put a 2nd gen pump on it (has 2 return ports) and replaced all the lines at the same time. (still stock replacement chevy lines though except for the return, which is just off the shelf power steering hose)
-Joe
Gots_a_sol
Postby Raymo » Sat Dec 24, 2011 8:58 am
I've seen the pics of your conversion in the Lounge. if you still have your GM engine, just pop the reservior off the original pump and put it on the Cummins unit.
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby kenmartin » Mon Jan 02, 2012 1:51 am
thanks guys you guys are great!
kenmartin
Postby scottdevall@yahoo.com » Thu Jan 05, 2012 5:20 pm
how long is the shaft need to be to hook up the brake pedal top the the hrydoboost.
the guys over at lee steering are going to modifiy that for me so i was wondering
Postby Gots_a_sol » Fri Jan 06, 2012 6:56 pm
I just measured the vacuum booster and shortened the hydro to match (I cut the end off the vacuum booster and welded it on the hydro booster so the end would be the correct size also)
-Joe
Gots_a_sol
Postby cutterman » Tue Feb 19, 2013 11:48 am
What did you do with the diaphragms that are mounted on the pump drive? Do you have a picture of the back of your pump pump set up?
cutterman
Postby BILTIT » Tue Feb 19, 2013 12:56 pm
His is a 93, wouldn't have diaphragms. I think 91 was the changeover year to the new pump without diaphragms.
Derek B.
BILTIT
Postby cutterman » Tue Feb 19, 2013 9:09 pm
Ok, so I picked up a used drive off of an 04 so I won't have the diaphragms. Does anyone know if this will bolt right up, as in correct gear to mesh with a 90'.
cutterman
Postby cutterman » Fri Feb 22, 2013 9:40 pm
even the 94 pump drive has a vacuum line on it to run cruise control. I won't be running a cruise on my build so any ideas on what to do with the vacuum port, plug it? vent it ? I am not sure.
cutterman
